Intercooler Pump Cavitation & Shutdown
#221
Personal opinion is that this is being way over complicated which I believe mirrors your opinion
Step one... Gravity feed the pump from a tank. Personally I would remount the pump so that it also feeds from the top instead of the side instead of just swapping around hoses.
Step 2...If you still have issues, get rid of the pump that shuts down when it aerates
#222
Personal opinion is that this is being way over complicated.
Step 2...If you still have issues, get rid of the pump that shuts down when it cavitates
#223
The pumps are not the same. Your facts are wrong, and you are putting me on the defesnse now because you keep pretending you know what you are talking about, so much that you can tell me i dont know what im talking about, and am some fool on the topic, instead of do research on what im saying before you tell me it is not true.
You are proving the inverse every time you counter me.
And yes, there are customers of yours who still have 3 min shutdown, but its much less often, so they don't complain to you, as the added cooling is enough to keep them happy...
However, im trying to solve the problem completely, i want no shut downs ever.
And the zr1 may have completely solved it already, and it has NO res tank at all.
Sorry, but that is reality
Why are you guys are not data logging a zr1? (other than they are hard to get hands on, but im sure there are people on the forum who race them who could supply you the data logs needed to determine if they shut down for 3 min, EVER. If they dont, 2 pumps are the way to go)
#224
Premium Supporting Vendor
GM believes the orientation is key to the pumps long term survival, and thus one is meant to be oriented vertically, and the other sideways... yes they are the same pump essentially... no... they are not the same part number. My facts are correct. The zr1 uses one of each pump.. both part numbers. This is not an accident or GM wanting to make things more complicated... if they were the same pump, they would use the same part numbers on both sides of the car... but they dont use the same PN on both sides.
#225
I wouldn’t base something on “why would GM”. Why would GM make a car that you have to do this much reasearch and put forth this much effort for it to operate properly. Second why log the ZR1 when it’s just a copy of LG, Tikt & G-Speed. Also GM has a different part number for the front spindles on a C7z for 2019 and there is zero difference between it and earlier MY’s.
IF gm didn't use a res, they didn't copy your system... adding heat exchangers to a car, is common sense.... which they should have done with the z06, but whatever.
#227
not on the same year car, from production. It would not be 2 different part numbers. I have the other pump on order, which ends in 02, i will test it soon and show side by side comparison. It even specifies that the 02 cant be used in the stock z06 pump location, in the pumps description, it is only for caddy and camaro. They are different.
Mikec7z (08-05-2018)
#229
you'll find that the 02 pump, the inlet is always pointing up, and the 03 pump, the inlet is always pointed sideways. ... no matter what car GM uses them in, no matter which bracket they mount to. There is a reason, and it is likely a lot more than the "bracket", which is already separate piece and part number, changing from car to car.
#230
If the bracket comes with the pump, the entire assembly will get a different part number, even if the pumps are the same.
The other option is firmware/software within the pump. If thats different, that too would require a different part number.
#232
pump having a different brain... i agree, it might. Thats why i bought one and as soon as it gets here i will test it. I mentioned this long ago in this thread.
#233
#234
Mikec7z (08-15-2018)
#235
ive been out of town a couple weeks, and the 2nd pump is sitting at the post office by my home. ill let you know as soon as i play with it, prob make a video of it working etc. Sorry for delay
#236
Alright guys, got the pump ending in 02, and now i just need to get the 5 pin connector to plug in, and with that being said, i have no clue which wires will need what voltage, and i dont want to just play russian roulette because i might cook the pump's brain if i put too much power to one of the pins.
Anyone have any advice? GSpeed, how did you guys go about this, probably had it plugged into a car im guessing? I would REALLY prefer not to have to take my car apart just to power this pump. Thanks for any advice in advance.
#237
On the LT4 pumps, pin 4 is ground, 1 and 5 are 12v
Mikec7z (08-21-2018)
#238
both 1 and 5 are the same polarity 12v? both positive correct? Or one of each pos/neg?
Is 4 on the left or the right side in this image? The clip/tab/catch is on the top of the plug in on this photo.
#239
Pins 1 and 5 both need battery +12v. It can be the same wire just split to two different pins. Pin 4 is ground.
The pin Numbers are written on the inside of the connector
#240
ill buy the clip tomorrow. Thank you for the help. Had i had it in my hand already, i probably would have noticed the numbers
... then again, probably not, because i just noticed the numbers are below each pin in the pump... dark in there tho, so hard to spot.
So we are positive that pin 2 and 3 are useless... and not part of a relay that comes on when the car hits a certain temp? Or do those output a signal back to the car that the pump is on when it is on?
Thank you again.
Thank you again.
