Power Steering Failure - ON THE TRACK !!
Attended a track day today and was running the car fairly aggressively and got a signal on the dash of a power steering issue..... just before the steering wheel froze at 80 MPH and turning into a corner. Glad the brakes worked !!! Let the car cool down and the power steering worked again. Took it out for another session.... same thing happened. Loaded it onto the trailer and headed for home.
The cooling system was running about 240 when this happened. Outside temp was 88 degrees.
Ok, so I did the research here and could not find any threads on this issue.... anyone have any ideas / thoughts ??
Thanks,
Dave
Thanks,
Dave
MRHTRD (07-14-2016)
Same thing that happened at WSIR, Autoclub speedway, Streets of Willow, and yes.....Spring Mountain.
Par for the course......until you get the PS cooling duct.....
xx0311xxZ06 (07-13-2016)
MRHTRD (07-14-2016)
I got the part number and installation instructions elsewhere here on this forum, gave those to my local dealer and had them install it. If you are planningbtominstall it yourself, I recommend one of the sponsors from the forum. I've ordered several items from Cultrag and have been very pleased.
Here is the latest I've seen on the PS overheating solution. I had the kit ordered and installed through a Chevrolet dealership and haven't had any problems.
https://www.corvetteforum.com/forums...ails-here.html
Post #1 on that thread contains a link to a PDF file with the GM notification information, installation instructions, etc.
MRHTRD (07-14-2016)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
On at least 2 other cars, I've had the PS go out (but not for heat-related issues). It's always a big surprise esp. on the street when turning a corner, or sweeping into a curve. One more reason for using both hands (on the street, that is) because you never know when/what will happen.....
It's a street car. It is track-capable. I have not heard of any overheating instances other than from people who track the car, and there are GM add-ons that do not affect warranty to mitigate these heat problems.
