Engine problems with my 6-month old Z06
Cruising
I have to say I'm really bummed. I took delivery of my Z06 / Z07 convertible in early February, and it's the wildest, most beautiful car I've ever owned. Absolutely love it, aside from almost killing myself several times and a few changes of underwear. Only 1800 miles on it, out driving in it on Sunday, somewhat harmlessly blew past a slow driver, and suddenly I heard what sounded like a wounded lifter. Tapping like an old typewriter. Took it to Chevy today. They first thought it was because they used the wrong oil (didn't use a non-foaming synthetic) on the first oil change, but after another oil change it was no better. It's headed for the dealer again on Monday, and they believe it is likely a cam & lifter replacement, but they've also suggested GM won't let them rebuild it, and I may be looking at a complete engine swap. Not happy. I heard there were some issues in 2015 with the Tonawanda plant, but I also read where they got to the bottom of the issues (metal filings left in the crank case) and they fixed the process. My questions are:
- Anyone else have a similiar issue? If so, what was the outcome?
- I'm assuming that because my car would no longer be numbers matching, I'm going to take a hit on resale value. Or will I? Would the car get some additional consideration being that it was an early failure replaced by the factory under warranty?
Thanks much for your comments.
Sorry to hear of your issue.
Lifter fail happened to me as well.
Unfortunately, the dealership I had it repaired at, went ahead and replaced the lifter/tappets without changing the cam. Had I known they were going to do that, would have demanded a new engine.
Then the diff died. Took em well over a month to R & R due to some kind of backorder......
My buyback is complete, and am now Vettless as of yesterday.
Therefore, today's announcement of cooling improvements certified for track use in 100℉ ambient was nice to hear.
Cruising
Ouch. Not good. I'm no engine mechanic, but even I know you don't fix a lifter problem without replacing the cam.
If you don't mind me asking, how many miles on it at the first failure, then the second failure? Was this a lemon law buy-back? Did you get the full price of what you paid for the car?
they replaced my rear end at 500 miles.had it for 2 days,did a great job.2100 miles no problems.demand a new engine.
2.No. It was a straight buyback.
3.No. But i will say it was an satisfactory amount, and handled professionally by Customer Care Dept.
ddinunzio (07-21-2016)
Received 8,916 Likes
Unless you plan on keeping the car for 20+ years numbers matching doesn't really mean a thing. However, if you do keep it that long being the original owner that is selling the car and having all of the dealer supplied repair orders showing a warranty replacement more than likely will over ride any originality concerns. I blew the engine in my 08 C6Z in 2011 and GM replaced it under warranty. When I traded the car for my 15 Z in 2015 nobody cared about the engine not being original, just that it had been replaced properly. I got the same market value for the car as if it had the original engine.
Bill
Bill
Cruising
Thank you Bill, that's really great to hear. I appreciate you responding to my thread. Best of luck!
Bill
Bill
I don't know if it shows up in Carfax, but it would show up if someone searched dealership service records.
I'd take the new engine but only if they're fairly certain of what they're fixing, or at least that it's deep and internal. It really beats having them do an engine teardown unless you have a stellar tech, and it's so hard to know in advance who you're dealing with unless you really know the dealership.
I would not sweat "numbers matching". I had my rear end replaced at 500 miles and the thought of it crossing the block at Barrett Jackson in 2045 did cross my mind (you know, it has an asterisk because it's not original rear end) but reality returned quickly... no one will ever care.
And you'll have your solid, fun, Z06 back to drive again (after another breakin period!)
2019 ZR1 (08-05-2016)
Cruising
An interesting development...
Thanks again to everyone who provided a comment.
I spoke to the owner of the dealer I bought the car from up in PA, who is well connected within GM, and also a big motor-head. He called GM and was told the following:
- The repair will have to cost at least 80% of the cost of a new engine before GM will approve a swap. If it's a simple lifter and CAM repair, I'm OK with that.
- More surprisingly, he was told that GM stopped stamping the VIN on the engines "some number of years ago", however they didn't quantify. Allegedly the only number on the block is the casting number, which would obviously not be unique to just my car. If that's true, an engine swap should not be a problem. I already shared this with the local dealer here in SC, and they will attempt to verify this.
Cruising
Sorry to hear of your problems.
I too had engine problems with my '16 Z. It began to consume oil, so the dealership went diving in to see the issue. There was a tremendous amount of carbon buildup with only 13,500 miles on the car and they found a damaged cylinder wall, so GM decided the engine needed replaced. It took about 9 business days for the dealership to get the engine then another 3 for the install.
It came back to me with less throttle response than what I had come to know before the issues. It was determined that the MAF sensor was dirty, so they cleaned it up and as of now it has been performing like it used to. It's good to hear they don't number the motor anymore.
Best of luck to you and your car.
Cruising
Thanks for your comments Baha. So sorry to hear about what you went though, including a second repair. All you wanted to do was drive it again once you got it back, only to have to send it back again. At least they resolved it and you're happy. And... if what I was told was true, you're also in better shape with GM no longer stamping the VIN on the block.
Numbers matching isn't even a thing anymore. As your dealer said, there hasn't been vin specific numbers on blocks/heads/etc for a long long time.
ddinunzio (08-05-2016)
Cruising
Well... after a couple of weeks, the motor has been pulled, and the problem was found. Metal bits in the oil, spun rod bearing. Not good. I gave them the go-ahead for a new motor. Not a happy camper. Yet another Corvette motor failure with metal bits in the oil. GM is looking to see what I want for compensation. Does anyone know anything about what they can offer me? What I can ask for?
Cruising
The dealer's initial offer was a year of free oil changes or a year of OnStar. Nope... They're asking me to quantify my costs, which is ultimately loss of resale value no longer having a numbers matching Z06. I do now have a case opened with GM corporate. Trying to educate myself so I can hopefully find out what is the most I can expect. By the time the new engine is delivered and installed the car will have been in the shop for more than 30-days, which does put it into Lemon Law territory.
Did you order the vehicle or was it a dealer stock purchase? Just wondering about time frames and when yours might have been built.
Cruising
I thought this issue had been discovered and remedied way prior to the date you took delivery of your car.. and that the 500 mile oil change would help IF anything was still in there.. this is disconcerting as mine was ordered and then delivered in December of last year, prior to yours.
azcanuk (08-05-2016)
