Lowering Bolts vs LG Lowering Spindles
Turn 12!
Just had the LG lowering spindles put on. Better ride, no noises, I should have done this long ago. The WCC bolts are Crap! These are them after 4K miles.
WCC bolt Top, Stock Bottom.
Stock on Left, LG on Right
WCC Bolts after 4K miles.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Did you do the install or pay to have them all swapped? Difficultly and/or install price?
I hate how high the Z07 sits but I really don't want to screw with the ride height because I track the car, and stock bolts make very minimal difference anyway.
I am debating if I want to go the LG spindle route but am up in the air at the moment.
Turn 12!
I have a Z07 as well. I went with the aftermarket bolts because of the rear lowering issue; mistake. The spindles are the way to go. Now it's sits just like before but the handling is vastly improved because it allows the natural course suspension travel. And no more noises.
fleming23 (08-18-2016)
Turn 12!
I had them installed by a Speed Shop. 800 bucks. 5.5hrs
Looks like nothing has changed with the WCC bolts. Zip claims that theirs are better, but you cannot go wrong with the drop spindles. They are, however, QUITE pricey.
Turn 12!
I have been reading that ALL aftermarket bolts are suspect. They still limit the level of suspension travel. LG seems to be the most legit. Pricey yes, but after all, our cars are in the 6 figures.
Platinum Supporting Vendor
The LG spindle is a better way all together but price prohibitive for allot.
pelotonracer2 (08-19-2016)
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
If you want the car lower to look good at car shows then lowering bolts aren't too bad, but they won't last long and you're compromising how well the suspension works.
If you intend to drive the car even half aggressively or track it then the spindles are the only way to go.
Turn 12!
American car manufacturers keep companies like Eibach, etc. in business with the ridiculously excessive fender-well clearance.
Geez, come on...we can do better!
Of course, if they did it right then we would have one less thing to complain about...so there's that.
Seriously, why do the Germans usually get this right and Detroit never seems to?
Any before and after pics. Also I assume you had to realign the car? Same specs or were they different?
A pet peeve of mine...
These are absolutely the only way to lower the Z06/Z07 properly to maintain the correct suspension geometry and keep
the car handling safely. These lower the car exactly 1-inch if no other adjustments are made to the suspension. The car
should be checked for alignment afterwards! The Z07 in particular has the exact correct looking stance afterwards.
I traveled down to Lewisville, TX the last week of June to have LGM install these on my Z07 and I believe it to be perhaps
the best mod for both performance-handling and aesthetics that one can do.
One should not lower the car by adjusting the lowering-bolts and especially by installing bolts that will allow more travel
than the factory bolts!!! It reduces spring-tension, altering the way they will work and reduces the amount of shock travel
allowing both the bottoming out of the shocks and the car!!!
_
_
than the factory bolts!!! This changes the spring-tension altering the way they will work and also reduces shock travel
allowing bottoming out!!!
_
_
BTW, is that your lowered car in your avatar?
If so, can you blow up the pic?
How exactly does lowing the car using the OEM bolts adversely affect handling?
I have a Z51 which is lowered using the OEM bolts. I track it often & want the suspension working optimally, since I am trying to become a better, faster driver.
Thanks.
Thanks.
Turn 12!
Check out this video. It may answer your question better.
https://www.lgmotorsports.com/lg-mot...-spindles.html
pelotonracer2 (08-30-2016)
