OFFICIAL 2017 ZO6 INFO straight from GM!!!!
I'm at Carlisle and met a worker from thr plant driving a 17 ZO6 (no names sorry) and I seen the 17 Zo6 in person that he was driving...
Facts:
1) No hood changes besides thinner interior hood pad to clear taller Supercharger lid.
2) Cooling bricks/blocks are same size BUT using different angles to cool rear cylinders (which seemed to be the problem of cars going into Limp mode)
3) No Bumber Changes
4) only on manual cars they will use the intercooler for the automatic as engine coolant instead, along with previous radiator
I have pics of car (Hood closed tho sorry guys not my call) I will try to post on ph or when I get back home on Sunday.
The following 4 users liked this post by BigNastyZO7:
The following 2 users liked this post by Jpjr2016:
GSpeed (08-27-2016),
pelotonracer2 (08-27-2016)
Go to the GM tent, a black rose 17 sits with the hood open. Larger cover is the only obvious change visually.
I REALLY need confirmation on a freakin cooling fix. I ordered another A8 because of the posts saying GM had improved the cooling to 100 degrees ambient. GM needs to speak up. May have to settle for the M7? We were assured by our connected CF members we would know something this weekend. NOT HAPPY. Any firm date when '17 Z production starts?
Supporting Vendor
There are two separate issues with these cars, like we have stated from the get-go:
De rating due to blower temps or pump cavitation/pump shut down
engine over temp due to cooling system inadequacy.
It appears GM has focused more on the loss of power, than the cooling on track. The M7 has a problem that has been "fixed" where the A8 is still problematic.
Unfortunately, par for the course.
GM official word was A8 is meant for one hot lap followed by a cool down lap. Customers planning to track the car should go with manual. They never made any other statements to say A8 is good for road course so if you have problems with 2017 A8 on the track then it's on you. Don't take forum opinions as facts and later scream that GM lied to you.
My advice, go with manual
Received 3,805 Likes
"Ask Tadge" Producer
Please be careful with statements such as "par for the course", et al. You're not as knowledgeable about the situation as you think you are.
So does that mean they plan to have a solution in place for the '17 A8 cars and not just the M7 stuff that was revealed this weekend?
Received 2,681 Likes
2018 C5 of Year Finalist
I'm going back and forth with the M7/A8 debate as I only plan to track my Z06 2-3 times per year. However, don't want to limit my track time to one hot lap at a time with an A8.
Facts:
...or is the ultimate solution the A10? I would also like to know if there is going to be an A8 solution for the 2017s or if this is it.
Since there is no clear direction on A8 and most likely it will never run cooler than M7, I would listen to GM and get M7.
I had A8 Z51 and M7 Z06. Both were fun to drive but I know prefer M7.
The problem with A8 as explained by GM is its close ratio transmission that keeps the rpms high and therefore generating more engine heat. Therefore A10 would make the problem worse. Not to mention fitting two more gears in the same tight space will cause less room for transmission fluid. I don't see how A10 is the solution. It would be a bigger problem at the track. If anything they should consider A7.
Funny that the C7 generation Z06 was the first to offer both a coupe with a removable roof and a convertible, both with an automatic transmission. People flocked to these options which expanded the market, however for the true track rats, the M7 (fixed roof) may be the best solution and maybe what the future ZR1 will offer.
Plus, this now gives me a legitimate excuse to tell the wife why I chose the M7, plus it saves me $3K over the A8!
For those who saw/heard Harlan and other GM staff say the A10 will not fit in the C7 and doubted it, on a road trip in rural Wyoming, I ran into a lead employee who works for the manufacturing company that has the contract with GM to produce 7,500,000 A10's over time (and yes, many are also going to brand X). He confirmed that not only is the A10 2" longer than the A8, but this it is to possible to not modify it to reduce its longer length and retain its 10 gears.
AFAIK, a driver can maintain any RPM he wishes...
Otherwise, there isn't room for a man's natural ability of creative truths.
like I said buy the 2016 leftovers for huge money off.you will be happier now and down the road when you go to trade it.
Supporting Vendor
Actually, we know a lot more than you'd like to give us credit for. But that's ok and par for the course
Having logged more track miles than any aftermarket
Company with this car, short of GM, we know exactly what's going on, and what Necessary steps need to be taken.
It's ok that they didn't fix the auto, it puts food on our families tables.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
The following 2 users liked this post by GSpeed:
Harris (09-07-2016),
Rodbuster56 (08-31-2016)
I'm asking because this could lead into a lower cost kit made by you and if swapping the oil coolers location with the intercooler makes more sense now? Meaning two oil coolers on the sides and one intercooler in the middle?
