Has anyone experienced ECM not allowing you to a do burnout at drag strip?
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Went to the track today and I was caught off guard, BIG TIME, when the nannines on my 2016 Z with A8 trans did not allow me to do a burnout while in regular sport mode with just T/C off. The ecm was killing all power to the ground (yes t/c was certainly turned off) while in the above mode when I tried doing my burnout in drive. After that was a failure I then imediately tried doing the burnout in manual mode in 1st gear (and car would not allow me to do that either)!
Has anyone in an A8 tranny car experienced this and if yes what exact mode where you running in?
More importantly, what has to be done to avoid this happening again?
Also, when this happened to me today I had my air pressure in my Nitto drags 345/30/19s mounted on C7 Z 19 inch knock off rims and the tire pressure was lowered to 21 lbs, and my ecm picked up on that fact as the dash cluster DIC said low tire pressure. Is this the reason this happened, the ecm knew that I had too low of tire pressure and nannies kicked in not allowing me to do a burnout?
Fore58 (10-08-2016)
GSpeed (10-09-2016)
St. Jude Donor '06
Has this ever happened to your at the track when you just had TC off and not Stabiltrac/active handling?
I had a track rental this past Thursday at Atco Dragway, made 4 passes and never had a problem doing a burnout. Running 345-30-19 Nitto NT05R drag radials on 19 x 12 C7 Z06 repro wheels with TPMS sensors installed. Traction control off. Hit the button once. Left active handling and stabilitrak on. Low tire pressure light was on all day. BTW this is my 3rd track rental with the Z06. No issues whatsoever.
St. Jude Donor '06
I am running your exact set-up for rims and tires and did exactly what you stated above and on one of my burnouts some major nanny kicked in not allowing me to do a burnout at all in drive sport mode (with TC off), and then in manual (first gear) in the same mode. Car was almost acting like TC was kicking in but it was not it was turned off, and the guy working the Christmas tree thought I had it on also and when he came up to my car I showed him the ICON on the DIC Dash Cluster display that indicated TC was in fact turned off.
I will chalk it up to some type of bizarre situation where some nanny was kicking in (for some strange reason) and hopefully that won't happen again.
Is there any chance the car mistook your right-pedal action during your burnout as an attempt to initiate launch control?
If your braking is too heavy (and no waterbox, for example) and the tires don't turn before the throttle has gone to about 50%, I've found the car goes into that "limit RPM against the brake" mode and won't do a burnout.
So, flash the pedal a little quicker, find some more forgiving surface, use some bleach, whatever... no, not really bleach, it's hard on tires!
St. Jude Donor '06
St. Jude Donor '06
So nobody else in either an A8 or M7 tranny Z has experienced some type of nanny (maybe torque management, TPMS warning light, stabiltrac/active handling, etc.) preventing them from doing a burnout in the drag strip while Traction Control (only) was turned off in one of the basic (non Track PTM setting, i.e. Sport 1, 2 or Race) either in Touring, Sport or Track mode?
Thanks in advance for any knowledgeable input on this subject.
I agree with Dave 396LT1. You can't roll into the throttle. Have to flash the throttle quickly. Also make sure you have enough water in the water box and go through it. And with the tire pressure you were running in the Nittos I believe you said 21 or 22 lbs. you shouldn't have had any problems doing a burnout.
Mopar Jimmy (10-09-2016)
No, there was no way I was in launch control, b/c you have to be in track mode first and then go to your PTM modes and put the car in Sport 2 or RACE mode to access launch control. I was not even in track mode when this happened, I was in regular Sport (Not sport 1 or Sport 2) with just T/C off and also with TPMS warning b/c my Nitto Drags on bad where aired down to 22 lbs.
I think you overlooked the solution in my post.
St. Jude Donor '06
Thank you.
The manual says that Launch Control requires PTM, which is not available in Sport or 'normal' Track.
