Sponsored by: GEM Motorsports
Fluid MotorUnion C7 Cat-Delete Pipes (Group Buy Info)
Old 01-13-2017, 07:41 PM
  #61
Satanspawn
Satanspawn's Avatar
Had these installed today. The sound is ungodly! LOVE EM!
FluidMotorUnion (02-13-2017)
Old 01-13-2017, 08:53 PM
  #62
TRANS DAMM
TRANS DAMM's Avatar
Received 1,156 Likes on 531 Posts
Any more exhaust smell then normal? I'm afraid of smelling like a gas station like when I get out of my buddies Z with long tubes. It could be his tune though that's why I'm asking
Old 01-13-2017, 09:09 PM
  #63
Satanspawn
Satanspawn's Avatar
No tune for me, cat-less borla X, and there's definitely more of a smell. I'm personally comfortable with it but I could certainly understand it being too much for most people.
The following 2 users liked this post by Satanspawn:
FluidMotorUnion (01-18-2017), TRANS DAMM (01-13-2017)
Old 02-10-2017, 04:30 PM
  #64
evokiller
5th Gear
evokiller's Avatar
Default C7 Cat Delete
Originally Posted by FluidMotorUnion
Deposit received and name added. We'll be following up with you when ready to ship.
Thank you Mike,
Pipes fit C7 Z06 M7 perfect. No problems with O2 sensor bungs.
Old 02-10-2017, 07:23 PM
  #65
VictorBarron
VictorBarron's Avatar
I assume the main cat delete will void warranty?
I want to go with the kit but don't want to shoot myself in the foot.
Old 02-10-2017, 07:35 PM
  #66
evokiller
5th Gear
evokiller's Avatar
You could use the Mini Cats and no tune. I'm doing LPE 720 kit with cat bypass. Should have dyno numbers next week.
Old 02-10-2017, 07:52 PM
  #67
VictorBarron
I was planning on doing the same with Big Daddy mini cats.
My instinct tells me you could be screwed if the dealer finds the main cats gone.
Old 02-10-2017, 09:07 PM
  #68
dvandentop
dvandentop's Avatar
these work on the m7?
sounds like it will be in touch what is the wait time on the kits?
Old 02-13-2017, 12:48 PM
  #69
0FluidMotorUnion
Former Vendor
FluidMotorUnion's Avatar
Thank you Mike,
Thanks again, hope you're enjoying them!
Old 02-15-2017, 01:38 AM
  #70
evokiller
5th Gear
evokiller's Avatar
Here's my dynojet numbers:
First: Base with AFE, Borla X-pipe.
Second: Above with LPE stage 1
Third: Above with Cat bypass pipes
HP Gains with bypass pipes but not as much as I had hoped.
Huge Torque gains.
I'm in Calgary, Alberta at 3000 feet
Still cold here with some snow so haven't had a chance to open her up.
Comments welcome.
Old 02-15-2017, 01:27 PM
  #71
VictorBarron
Huge Torque gains.
Comments welcome.
Wondering if your car is throwing any codes with the 02 mini cats.
Old 02-15-2017, 03:14 PM
  #72
8850
8850's Avatar
Curious why the pipe is not centered to the flange? Seems to me flow would be improved were it much like the factory. The front two cylinders look to be restricted. Maybe difficult to manufacture that way?
Old 02-20-2017, 01:41 PM
  #73
0FluidMotorUnion
Former Vendor
Thanks for the response. That was a design we decided to use for the flange since it looks much cleaner and the flow is pretty comparable. We are working on changing it slightly with our production design so we'll keep you guys posted.
Old 02-25-2017, 10:23 AM
  #74
Dfwz06
Dfwz06's Avatar
Is the group pricing still going? I need a set
Quick Reply: Fluid MotorUnion C7 Cat-Delete Pipes (Group Buy Info)
