Any battery maintainer connections under hood?
So, I parked my 2016 Z06 in the winter storage area about 3 weeks ago after it sat in my garage for about 3 weeks without driving it. Long story short, I went to start it to move it today and the battery is too low to crank it over to start it. I can open the doors, lights come on, etc but I can't get the rear compartment to come open so I can put my battery tender on it to try to recharge it. So, I've two questions. Is there a remote manual release for the rear compartment or is there someplace to connect the tender under the hood. I don't think I can get to what appears to be a positive connection on the rear of the fuse box. There are plenty of places to connect the ground.
Thanks in advance.
Thanks in advance.
Positive terminal under cover back of underhood fuse box.
Negative terminal connection
Wire path.
Quick connect plug. Wire is wrapped in microfiber and runs over the hood which is xpel protected.
Did it like this because the factory charger runs through hatch and every now and then wife and or kids use the overhead door as opposed to the side garage door and Scares the heck out of me lol.
Wire path.
Seems simple enough. I might try this technique ^^^
Lighter adapter
Thanks in advance.
Thanks in advance.
