Ramps vs lift
#61
Those are pretty good videos Larry. They show the lift pretty well. For someone without alot of room and who doesn't want to deal with a giant 4 post or scissor, I really feel this lift is a good, safe alternative. Money was no object for me. I picked the lift I felt was best for my purposes. One of my Vettes is still sitting on it as I type. I am up early getting ready to crawl underneath her. Gotta wait another hour or so I don't wake the house with all the banging and clanking I am about to create. Snow is coming on Sunday, and I hate having to fire up the loud jet engine salamander heater.
I don't work on cars as much these days as I've got a miniature 1 car garage, but I definitely wouldn't mind getting a bit more active again
#62
Larry, I don't understand your complaint. Fred's Race Ramps are awesome. Never had any problems.
#63
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I was changing the brakes on my buddy's S4 yesterday. First, I hate Audi, always have to do something different and second I've reaffirmed how much I hate jacks and jack stands.
And just ignore Mitch. He is trolling this thread. He doesn't understand that you can't change brakes or tires using race ramps. And he somehow found a way to bring up Hilary Clinton in a discussion regarding lifts! Amazing. Fred does have a real nice product though. It is of very high quality and for its intended purpose it does it well.
Mitch84 (11-20-2016)
#64
I've had Rhino Ramps for 15 years, they're great but limited in what you can do. Race Ramps aren't too different than Rhino Ramps except that you get all fours off the ground
I've saved most of my money by changing my own brakes, rear end, springs, shocks, lower control arms, sway bars, spindle arm, etc.
Can't do any of that on Rhino Ramps or Race Ramps
#66
I see the jack in the front, but I assume when you actually get under it you place 4 jack stands on the corners??? As a Paramedic Fireman for 27 years I have ran on a couple fatalities where jack hydrolics have failed, not a good seen. You can never go wrong with a few jack stands
#67
So to repeat for the 5th time, THE HYDRAULICS ARE NOT USED TO HOLD UP THE CAR. THE HYDRAULICS ARE USED TO LIFT AND LOWER THE CAR.
If you still wanted, 4 jack stands can be placed under the car in about 5 seconds. In the upper left hand corner of my second picture, you can see my blue jack stands available if I feel it is necessary.
So the car is held up BY THE LOCKING BARS, which when combined with the unit (WITHOUT HYDRAULICS) are rated to 5000lbs. I still have the hydraulics engaged in these pictures, which are ONLY A BACKUP. Then I have a second hydraulic jack as well as jack stands available if I am actually under the car. I am fairly certain that I am safer under my car than you are driving around the street.
#68
Mordeth- I advise always Jack Stands. The LOCKING BARS could fail. Welds are not 100% anymore. Better safe than sorry .... Good day friend.
#69
But... Really?? I guess the welds on jack stands can fail also. Or they can just break because the metal is inferior. Or there could be an earthquake while you're under the car.
But I'm probably a racist also so please ignore this...
The following 3 users liked this post by any4xx:
#70
Those with quckjacks, are you just parking your car over it daily?
I just wanted to know if I can just leave the quickjack there under the corvette to double up the garage space.
#71
I do. You can drive over them but not <on> them. So when I'm done with my work, I lower them then push them under the car and leave them there.
#72
Well, I did not vote for Hilary, but the idea of safely lifting all 4 corners with minimal effort (QUICKJACK)definitely has my attn. not to mention $1200 vs $1900,
One last thing, it seems to me that good old Mitch84 has already a couple of $ in 2 cents at a time
#73
#75
I got mine from GarageEnthusiast.com
They are a forum sponsor here. $75 discount to Corvette forum members. They were pretty good with keeping me informed of availability and shipping info. Mine arrived in about 2 weeks from order date. I did have a problem when I first ordered as my bank rejected the purchase. Ended up putting it on my credit card, who also rejected the order until I called them and told them to let it go through. Issue was on my end.
#76
I have personally witnessed two different sets of ramps fail. One set failed when the vehicle was about half way up the ramp. The other failed after being up on the ramp about 5 minutes. Lucky for you, you weren't under the vehicle. There are hundreds of welds on a car. If you don't trust welding maybe you should give up driving.
#77
#79
