Sponsored by: GEM Motorsports
--SNEAK PEEK-- LG Motorsports Carbon Fiber C7 Hood
Old 12-12-2016, 07:18 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default --SNEAK PEEK-- LG Motorsports Carbon Fiber C7 Hood
LG Motorsports C7 Carbon hood is getting closer to release now.
If you don't remember, this was the prototype using during this summers tests.
Molds are being finished up right now after the first test hood was pulled and I knew you guys would want to see a sneak peak of it.
I'll have more updates as I get them!
The following 2 users liked this post by Anthony @ LGMotorsports:
Painrace (12-13-2016), rsilver (12-12-2016)
Old 12-12-2016, 07:53 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
Looks good! Per the intro piece back in September, the hood has twice the cooling louvers as stock.
https://www.corvetteforum.com/forums...orts-hood.html
The following 2 users liked this post by AORoads:
Anthony @ LGMotorsports (12-13-2016), LG Motorsports (12-15-2016)
Old 12-12-2016, 08:11 PM
Toilets
Toilets's Avatar
Any weight reduction vs. the stock cf hood?
btw- how much does your front splitter weigh?
Old 12-13-2016, 01:41 AM
ernhart333
ernhart333's Avatar
WOW, that is a bad *** piece!!!
Any idea on a ballpark price for this hood?
Old 12-13-2016, 02:15 AM
TAK2TRK
TAK2TRK's Avatar
Nice job! How does it mate up to the stock shroud? Can't wait to get one.
Old 12-13-2016, 03:51 AM
AVETTE
AVETTE's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Great work as always Lou.
Old 12-13-2016, 08:21 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
Stunning!!!!!!!
Old 12-13-2016, 09:46 AM
ScGRaceR
Support Corvetteforum!
ScGRaceR's Avatar
looks sick! should help dissapate some heat with that grille set!
Old 12-13-2016, 10:38 AM
Former Vendor
I'll see if I can't get a weight on it here in the next couple days. I know they still have some trim work to do and get it to us so we can make sure it fits so I want to have it as close to production as possible before putting it on the scales.
The G7 carbon front splitter is 3.65 lbs
Old 12-13-2016, 10:44 AM
Speedforhire
Speedforhire's Avatar
Have you done wind tunnel testing on that design? I would assume that the enormous deflector in front of the vents will cause some backdraft. Perhaps forcing heat back into the engine bay.
I like that front splitter. What do those cost?
Old 12-13-2016, 11:12 AM
Former Vendor
The leading edge of the hood is there for the reason of sucking air out. It creates a Venturi effect on the back side, helping to suck out the air....not cause it to go back in. This has been proven numerous times. We used this same principal on the front of the hoods of the World Challenge cars to help create better cooling and increased downforce on the cars.
Old 12-13-2016, 11:28 AM
23/C8Z
23/C8Z's Avatar
Received 5,751 Likes on 3,173 Posts
All comes down to $$$$$. for me. like many others we all have these "lists" lol. I hope it's astronomical so I don't have to buy the roof and all the aero in it also!
Old 12-14-2016, 09:32 AM
0JDP Motorsports
Former Vendor
JDP Motorsports's Avatar
St. Jude Donor '12
That is a beautiful piece, Anthony!!!!!! I'll have a home for that very soon!!!
Kind regards,
Jordan Priestley
801-545-4215
Old 12-14-2016, 11:41 AM
Speedforhire
Your WC cars hood vents are not designed the same. The C7 hood vents (on your product) have recessed openings below the front lip which will indeed cause a backdraft because those vents don't maintain the same air flow path.
I'm sure you'll sell a few.
Old 12-14-2016, 12:36 PM
Former Vendor
We changed the hood on the challenge car because of what we did in the tunnel...and yes it looked just like what you see on the C7.
In fact if you were to have purchased a ACS World Challenge hood it has those "modifications" to some degree built into it because we sent them the skin off the race car. You can compare between the video and that unpainted hood to see some of the differences between them.
Again...yes that lip is there for a reason, and it works off the same reason the venturi in a carburetor works to help suck out the high pressure under it.
Old 12-15-2016, 11:08 AM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Backdraft? what is that??
With all due respect, the hood works. The air does not know what is behind the leading lip. Check the Acura hood that is running at Daytona as we speak. plus the CFD of the Corvette GT Lemans hood.
Without going into the entire aero theory, we have tested the hood configurations and with our on track testing, the front down force/reduction of lift at the front PLUS the increased air flow through the radiator confirmed and validated our hood design.
Also check out the CFD model of the corvette racing hood. The red indicates the high pressure as the air is lifted over the opening behind it. It creates a "Bernoulli" effect that makes a low pressure area behind the leading lip.
the louvers are there for two reasons, One, cosmetics because without a proper tunnel from the radiator to force all radiator air into this opening, the engine would be exposed to view and that would be ugly.
The louvers also offer an additional function to redirect any air the "tumbles" in the area at lower speeds.
This is not a guess, it is a fact. WE tried various hood configuration in the GM wind tunnel and in the Atlanta tunnel with another car and this configuration was validated a number of times.
I am glad to see the Acura NSX hood leading lip that is functionally the same as out LGMotorsports hood.
Hope that helps
thanks
Lou Gigliotti
LG Motorsports
Sébast19X (08-05-2022)
Old 02-15-2017, 07:26 PM
Former Vendor
I'll have a full write up release and pricing for everyone tomorrow but I had to share two pics of it in bare carbon!
To --SNEAK PEEK-- LG Motorsports Carbon Fiber C7 Hood
Old 02-15-2017, 07:43 PM
Dfwz06
Dfwz06's Avatar
Very nice. I had your carbon world challenge hood on my c6z, and loved it
Old 02-16-2017, 02:50 AM
rsilver
rsilver's Avatar
Looks great with the new front end. Down right bad IMO
foreverfuelie (02-16-2017)
Old 02-16-2017, 02:04 PM
foreverfuelie
foreverfuelie's Avatar
Quick Reply: --SNEAK PEEK-- LG Motorsports Carbon Fiber C7 Hood
