2017 Z06 supercharger lid installed on 2016 Z06
#41
2017 supercharger lid is on it's way for my 2016 Z06. hood insulator (84016133) and supercharger lid (126703730). the new lid looks great !!!! going to be a long week.
#42
Do you plan on doing testing?
I'm confident that my power package setup (CAI, x-pipe, 2.3 pulley, 160*, 17 lid) will net the BEST results for bolt on (no tune) only applications. You heard it here first.
#43
Saw this on another site. He could be blowing smoke, but its an interesting thought:
http://www.trifive.com/forums/archiv.../t-161270.html
Took me a bit to decipher "big hat charger" meant "2017 lid and bricks"
I can see now, that even SAE certified power is not created equal.
#44
So there was some concern from the intro of the LT4 about heat in the air charge inside the supercharger.
#45
Originally Posted by Speedforhire
It appears GM's marketing scheme is working.
#47
Yes! You can swap out the pulley without tuning, however, the pulley size in the tune should be changed. The stock upper is 2.995, so adding a 2.3....will spin the blower faster. The oem stock tune is so pig rich it will only benefit from a swap. Tuning is not a requirement, but some car owners do it anyway because they add CAI, headers, etc.,. I'm not going to install a CAI or headers.
I think Joe did a thread on it where he changed the upper and saw gains on a stock tune only car (1+ psi boost).
#50
Did the lid bolts come with it?
#51
Former Vendor
According to the stock ECU mapping they built in timing pull on cyl1, not cyl7 or cyl8.
#52
Received 2,379 Likes
#53
Former Vendor
True I don't know what is not present. That by cylinder static built in timing pull seems like where they'd want to shove those values though. I guess someone would have to break out a manual timing light to confirm 7&8 are running less advance.
#54
even so it may not be just at idle. it could be at wot over 3500 RPMs.
#56
Former Vendor
#57
you can email support to add things you feel you need and see if they can. maybe start a discussion about it on HPT.
#58
#59
What he said. HPT (or any tuner software for that matter) can only read what GM allows to be read. There's no "hidden" files that one piece of software is able to read while others cant. Either GM allows the files to be seen or they don't. Gander into the history on the LML Duramax and you'll see what its like to be completely locked out of the tune files by GM. Took several years for guys to come up with the hardware to crack into the ECM to be able to "see" the tune files but even then it was all ASCII code and no way to see the nice pretty colorful charts like in HPT or EFI Live. The point I'm making is if GM doesn't want you to "see" the files...you won't. And it doesn't matter which software package you choose to try and "see" them.
