DSC Sport Shock Controller observations
#601
Leeds.io
St. Jude Donor '14-'15-'16
Let me know how you get on at Little Bear with the alignment. I have the DSC controller, AMT camber plates, adjustable sway bar links and rear toe arms all sitting in my garage waiting for me to ever find the time to get them all fitted. I also have the stage 3 wicker bill, CF front winglets, Mamo TB, Burger air filter and Corsa X-pipe in the same pile. Working on my deck and recovering from a small surgery are driving me nuts!
I am in Ridgefield, so even closer to you than Gene!
I'm on Deans Corner Road.
Best,
Gene
#603
All I can say is WOW! What a difference and I'm so glad I did this
phantasms (06-08-2017)
#604
For those members in the NY Metro area, Little Bear Wheel Alignment in Buchanan NY has the tool to adjust rear caster and Brian and the crew over there do an awesome job period!
For detailed info on them, PM me...
george vee (06-27-2017)
#606
I am very happy with the launch mode and it sounds like before you start launching the car need to download the latest UI user interface and get a handle on the data portion you can log the launch there is a separate section just for launch it even will map out the clutch release lot of data any questions and there will be just ask Im happy to help. also the launch works in the rolling mode also there is a section on that there is a lot of power available. you can even call here we will walk you into the section
#607
https://www.corvetteforum.com/forums/southeast-42/
Bish
eric04 (07-23-2017)
#608
Former Vendor
#609
Former Vendor
410-799-7223
The following 2 users liked this post by DSC Sport:
eric04 (07-23-2017),
thebishman (07-23-2017)
#612
Converting .5mm to inches is approximately .020 inches.
Then you need to know the overall diameter of the tire. For the Z06, the fronts are 25.8" and rears are 26.6".
http://www.1728.org/toe-out.htm
So, -.5mm = -.020 inches = -.044 degrees for the fronts and -.043 for the rears.
#615
#616
Thanks... I should have been more specific in my question because there are different baselines for figuring this out - diameter of tire, diameter of wheel, length of the alignment tool. The question for Mike @ DSC Sport is what baseline are you using for the -0.5 mm toe measurement so I can convert this to degrees?
#617
I do wish DSC would provide a tolerance to their values, rather than just simply a hard value.
#618
I guess I don't understand. Wheel diameter doesn't matter, the overall diameter of the tire matters. This is just a simple trigonometry relationship. The diameters between the Z51 and Z06 Pilot Super Sport tires are slightly different, but not by much. And even though the fronts and rears are different as well it doesn't affect the angle by much.
Some alignment machines assume a fixed wheel/tire diameter, so we'd need to know what that number is because it's arbitrary.
Using degrees for the toe measurement is the universal approach because it's an absolute number whereas using a linear measurement is relative to the alignment method you're using.
#619
Former Vendor
#620
just put the DSC module in this afternoon for 2016 Z06 with Z07 package; ordered from Katech on Friday afternoon with touring-plush calibration file loaded and arrived today- that's service. I have not had the DSC-recommended alignment yet...
install notes:
i did the installation without removing the left front wheel but otherwise, mostly followed the forum install write-up. If i upgrade to ZR-1 and take the module with me, i will certainly remove the wheel. it is a tight fit and my left arm shows for it with grooves and light abrasions. I had several battery powered LED flash lights bathing the area behind the wheel well liner and predominantly visualized the work through the vent holes as looking from the wheel well opening was too restricted at the same time as my arm was in the work area. Also, removing the module tray by removing the 10mm bolt is the only way i could see how the OEM module could be removed from the module tray whilst the wheel in place. once everything was buttoned up, i found a 2 meter mini usb still too short-3 meter probably would have been best. Total install time: about 1.5 hr. Both USB port and wifi worked as advertised.
As for the payoff...WOW!
with the OEM module, i always found the tour mode strangely non-compliant; better than sport for long drives, but unsettled/rough road still made for a jostled ride. I never used track mode on street as simply too rough and no confidence in the tail end holding on whilst power applied. I usually stayed in sport mode and practiced caution with the throttle, especially in turns so as to not break traction. With the DSC operating, the power can be applied much more aggressively and traction control works without any drama at the tail such as wagging/sideways thrusting. Furthermore, in all modes, the compliance of the ride and the confidence inspired by the suspension work is considerably better than OEM. Even DSC sport and track modes are quite a bit more 'comfortable' on rough northwest Ohio roads than all OEM offerings and the tour mode is down-right impressive for cruising about. The DSC module truly is transformative for this car. I am looking forward to more seat time...
rob.
install notes:
rob.
Jacob (08-07-2017)
