DSC Sport Shock Controller observations
#903
Former Vendor
#904
What kind of hot pressure on track are your shooting for with super sports or cup 2? I’m still getting a lot of outside edge wear on super sports with the DSC street/track alignment and hot pressures of about 34-35psi. I don’t have the controller yet but it is backordered.
#905
#906
Autocrossing is not so different from road racing only happens faster technique is similar get behind the corner get to power or find the straitest line either way grip is King . All of the c7 competing in optima search for the ultimate street car use the DSC module . The off the shelf tune and my alignment are it . If you have been autocrossing alot work from there with slight ride ht adjustment . I find autocrossing my car I tend to run in sport mode leaving traction on . If it's not invasive your being smooth and that is fast . I was out yesterday autocrossing my biggest tool was tire pressure and being smooth put my best time in with tire pressure up traction on never interrupted dropped 2 sec
DSCSPORT will give you big grip faster turn in better power off no drama that is what autocrossing is
But what is the difference between the GM MRC update you can get at the dealer (whether it's free or 350 bucks etc) and getting this controller for nearly 4 times the price?
I know the feedback has been already stated and pretty much everyone has high praise for it. My car already rides fine the way it is with the new tires and alignment but of course if there's a better feel out there, i'm willing to go for it.
The only dilemma is that is it really worth the cost since my Z is a weekend car. The actual price isn't a big deal even though it is a lot of money, but idk if that actual price will justify my hopes for it.
And i really hate myself for coming into this thread lol
#907
Bish
#908
Quick question and sorry if this was already answered or talked about in this thread but this thread is too long for me to go through it.
in a nut shell: the factory controller is a STATIC system that comes with several basic configuartions pre-determined by GM that you then choose (Tour, Sport, Track). Once you’ve made your choice the parameters and responses are given based on what a GM chose, and REGARDLESS HOW TOU ARE DRIVING OR WHAT THE ROAD, TRACK, ETC THROWS AT YOU. It’s a static system.
The DSC controller is dynamic. While you still get to choose the drive mode (Tour, Sport, Track, etc), and the controller has a pre-determined set of parameters for each mode setting, it goes further in that it actually reads the various input senors from the vehicle to see what actual road conditions are being encountered and what the driver is doing (throttle, G’s, etc.) to DYNAMICALLY alter the response of your suspension to deal with these situations. It’s a live system that forms itself to what’s actually happening at any given moment.
So, if you’re driving along in Tour mode and you suddenly slam the throttle wide open and aggressively hit a series of S curves the suspension will respond to this rather than just continue along on the factory’s pre-set tour mode of soft suspension and floaty ride.
Plus... if you are interested you can actually change the various ride and response parameters in the controller to meet specific needs or desires... something you can’t do with GM’s system. The DSC controller is fully user programmable and customizable.
its a great system... moves the car to the next level... on street and on track.
Z0HS1CK (07-21-2018)
#909
I’m no expert but I’ll give you my take on this, based on everything I read for a year before making the leap... and my own experience after I installed the DSC controller in my 2017 Z06 late last year.
#910
I didn't think of it like that although the way you explained it, now it make sense given how advanced how suspension is.
I hardly use touring now unless it's a road i'm familar with and i know it's bad, i'll click it to touring about 1000 feet before i approach that bumpy road so it won't be too hard on me/car.
Other than that i always keep it in sport. I tried track a couple of times and that felt amazing, but the roads here are mostly bad, i think i'll do more damage to the car leaving it in track.
So you're saying it's active suspension correct? But what about the actual ride in each mode? People said the stock touring, becomes softer? And the stock sport, then feels like stock touring after the upgrade. Or do i have it backwards?
I don't want the floaty ride like in stock touring because it bounces too much. And in sport it rides perfect, but at the same time you feel all the imperfections in the road, whereas stock touring somewhat hides most of it.
Will this controller fix all these problems? I'm just digging and digging my way to justifying me spending to get it done. Like i said the actual cost isn't a big deal but if what i'm thinking is true, and if what i'm hoping from what you said is perfectly true, it may be worth it.
Otherwise since my car is only a weekend car, and gets driven about 4-5k miles a year, maybe i'll just leave it the way it is. It drives fine but i know it could be better.
#911
Just to add...
1. I'm NOT a "tech" suspension guy... and have almost zero interest in playing around or custom tuning my DSC controller. I ran mine right out of the box and was thrilled with the performance as is. BUT, if I had needed to customize anything the guys at DSC were more than willing to support and talk me through custom program changes (which I never utilized) and other users on this forum have swapped their customized "tunes" back and forth to help each other out when needed. So you don't have to be a techie to take advantage of this.
2. I sold my Z06 when I got my ZR1... took the controller out before I sold it... just waiting for Mike to supply me with the new firmware to be able to run the controller in my new ZR1. I miss it. The DSC controller in my Z06 was awesome. I never previously used Tour mode unless I was taking a long trip on the Interstate... but with the DSC controller I used Tour mode probably 85% of the time on the street. It felt great but instantly changed when my driving pattern changed. Better handling... better "dig" on acceleration... tighter on the cornering... just BETTER everywhere.
I went through the same "finicky" issues initially with the Z06... first board I got was part of the group that wouldn't work with the "new" 2017's at the time... Mike at DSC was unbelievable... supported me through the whole process... got me a replacement from the new chip set batch... checked it before he shipped it... it arrived and installed with no further issues. Frustration over. I can't say enough good things about my experience with them. As for the controller... it's worth the wait and the minor inconveniences I went through.
Honestly, it's the controller that GM should have built and delivered with every car... but then GM doesn't want you "playing" with these things... or customizing them either... hence why the new cars are locked and (so far) can't be tuned. This controller is like allowing the user to "tune" the suspension and driving modes.
#912
So it sounds like I'd be foolish NOT to spend $1300 on my car Looking forward to getting this installed, sounds like it will address most, if not all, of my ride complaints. Of course I was more than willing to just accept them and enjoy the car without this.
#913
Former Vendor
Just to add...
Just try this if you have your old DSCsport controller make sure you have at least 12-17-17 install DSC disconnect battery posive cable then momentarily short to ground to power down all ecu. Put the positive back on battery. We have cars on the track and the ptm works on the 18 up models when that is done . I'll be out a week at a time at Daytona then road America and I'll look at what the timing needs to be when the ecu go online .
All best man is the zr1 cool it is the only car I would trade my Z06 on I love that car does it all
#914
I can tell you from DSCsport we are proud of the Dealer core we have built with the C7 market. Coming from drivers seat and being a racer most of my life I am truly excited and lucky at the prospect of having LG join DSCsport. DSCsport is proud that we are represented by dealers and distributors that are at the top of their game always looking at the future.
#915
Mike, I should have mine installed next week sometime. Did you ever finish the tutorial for the virtual bump stops?
I did a search on youtube and found this. Is this it?
I'd like to know what i'm doing once I get it. I have LG drop spindles and i'm lowered on stock bolts pretty low. I need to get this dialed in so when hitting dips in the road, my front tires don't rub the fender lip/spats.
Mikec7z (08-14-2018)
#917
Former Vendor
#918
Does this mean you’ll have a working version for our ZR1’s at that time as well?
#919
Reinstalled mine to see if I still get service suspension error. Meanwhile I have a question. First time hooking up the laptop to it. When I read from the board or opening the latest pdts file on the first tab I see 20% value for right front gforce, is that normal?
