Girodisc Rotors C7/ZO6/ZO7
#81
How much are replacement rings only?
#82
Former Vendor
St. Jude Donor '13
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
GIRODISC FRONT 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL ROTORS
http://www.xplosiveperformance.com/G...rs_p_4086.html
GIRODISC REAR 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL
ROTORS
http://www.xplosiveperformance.com/G...rs_p_4087.html
GIRODISC FRONT 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
http://www.xplosiveperformance.com/G...rs_p_4084.html
GIRODISC REAR 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
http://www.xplosiveperformance.com/G...rs_p_4085.html
Xplosive Performance is online now Report Post
ROTORS
#83
Former Vendor
St. Jude Donor '13
2017 Grand Sports loses 18.6 pounds of rotating weight an average of 4.65 pounds at each wheel by going to Girodisc rotors and hats. Looses another 33.2 pound by going to a set of Forgeline GA3R wheels. 51.8 pounds total of rotating unsprung weight.
The Girodisc system is a direct replacement for the OE disc
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
ROTORS
ROTORS
#84
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#85
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#86
Hey,
I have a newbie question about a 2017 GS with CCB.
When you say your rotors are a direct replacement for the CCM rotors, you mean i can use my stock calipers(which came with CCB rotors) with your steel rotors right? No issues with fitment and all that?
#87
I have a 2015 Z51 M7. Lookimg to replace the brakes front and rear. For the rear, I'm thinking of purchasing the GM Z06 rear caliper, as this should clear the 20 inch wheel and a Girodisc rotor that is a replacement for the OEM steel rotor of the Z06.
Question, what is the size of the Girodisc rotor? The OEM steel Z06 rotor is 365 x 25 so the Girodisc will need to be the same size to fit with the caliper.
