Tony Mamo Ported TB installed
#201
UKnowWho18 (06-16-2017)
#202
#205
Ok...all done...quickest mod EVER...I notice the difference right away in throttle response for sure...I also have the Berger Motorsports Air filter...
I do have an idle issue though...it's hunting between 500 and 700 rpms...wondering if it needs to learn the new TB... anyone else have this issue?
#206
You may have introduced an intake air leak. Gasket not pinched? Ducts fully engaged? Clamps tight? Connector latch engaged?
#207
#209
forgot to post my install
Installed myTM in my A8 I was having a slight little hesitation when I would straight up hammer down from an idle stop but all that is gone now thanks to the new TB. Thanks Tony! Now my car goes into instant smoking wheel spins if I do that! Throttle response is instaneous!!!
#210
Hmmm....so yesterday I removed the TB and reinstalled it in case I didn't install it properly, all looks good and still have the idle hunting between 500-700 rpms, drove it about 100 miles yesterday, the acceleration etc is great, but this idle issue is a problem, going to contact Tony today....
#211
The first TB I sent him was damaged in shipping....USPS dropped the package and it cracked the extended plastic housing area where the wire harness plugged into (in spite of really good packing in the box....those who have received one of my units can vouch for how well I pack them). So I sent him a replacement unit right away and for whatever reason he is dealing with this idle hunting issue which is a first with approaching a couple of hundred units out in the field.
Anyway as the saying goes, Im hoping three is the charm! Working on his 3rd unit this week. Im not sure what other mods or conditions might have created the idle hunting he is experiencing (possibly even a bad TB), but hopefully we get it right this time!
Regards,
Tony
#212
#214
Seems NyVetteguy007 is my unluckiest customer....LOL
Regards,
Tony
Regards,
Tony
Tony is taking every step to make sure we get this right and I appreciate that, I'm looking forward to hopefully getting the new TB in my hands this week, once I do I will report back the results.
Thanks Tony and everyone for the help!
#215
New Tony Mamo Throttle Body + Other Mods
I ordered Tony's Throttle Body and as others have mentioned it was packed very well and a very easy install. Seems like a great product !!
I have an aFe cold air box, the throttle body and corsa x pipe and axle back exhaust. I also have the Vitesse throttle body controller installed and an MGW shifter on my 2016 Z06 Z07.
All of the other mods were installed before I installed the TB. Took the car out last night for a few hard launches as I am getting ready for the drags on Friday night and after a couple of very clean launches in race mode, the check engine light comes on. So there is obviously a code there.
Has anyone else experienced this and how can I get the code without going to the dealer ?
Thanks guys for your help.
Dave
Dave
#216
Dave
Dave
You may want to disconnect your battery for 10 mins which will likely reset the CEL. If it comes on again, you should buy a OBD II reader on Amazon in order to see what the code is. You can get one for $20.
My 2 cents.
MRHTRD (06-15-2017)
#217
Dave
Dave
I keep my scanner within hand reach behind the passenger seat back and have gotten good at clearing the code while driving.
Only other option is return it to Tony who will send you one ported a little less than the one you have.
Also, my 2017 car is 100% stock except for the PTB.
#218
St. Jude Donor '10, '17-'18-'19
I learned a long time ago in life, business etc, it's not the problem but how the problem is handled that matters.
I got mine and installed it, no issues with idle and I could tell that it throttle response was improved. it was packaged so it could take a nuclear blast... LOL
The car is at the tuner this week where they are adding the headers, xpipe and a tune. Look forward to driving it. They will dyno it as well but not looking for any meaningful gains. Just over seat of the pants feel.
#220
I'm going to guess you have a 2017. Regardless, it will be a P0121 Throttle Position Sensor Code. Does no damage or cause adverse side effects other than the annoying CEL. Buy a Harbor Freight OBD-II/CAN reader and clear it. They're about $20 if memory serves me. Also, any parts store will use their scanner and clear it for you for free. Keep the scanner close as it will very likely throw the code every time you drive the car. The car does not "learn" what was changed and resolve the issue.
Thanks,
