Jacking Pucks that stay in
Does anyone know if the ZL1 addon jack pads come as a set of (4) or are they 59.99 a piece? The ordering page has a quantity selection before you even put it in your cart, kinda threw me off
You can get a set (4) of the URO's from RockAuto for under $30 and shipping ($8 for me to the East Coast).
ÜRO PARTS 51711960752
Good luck... GUSTO
Good luck... GUSTO
CF Senior Member
I went with ZL1 add ons. Allen wrench clamps them into place. Easy, peasy.
https://zl1addons.com/collections/ja...nt=28961300929
These are awesome, I've had a set for about 6 mo.
https://www.corvetteforum.com/forums...nts-pucks.html
2022 C8 of the Year Finalist - Unmodified
2022 C2 of the Year Finalist -- Unmodified
Thanks,
-Garry
I also use the ZL1 pucks on mine; however, I also use a hockey puck between the ZL1 and the pad on my lift. I used the Reverse Logic ones before and they had been thick enough but they are so thick that I had to drive up on a piece of 2x12 so I could install them (I park over my lift). With the ZL1, I have just enough room to slide in a puck without needing additional clearance. While I tried the lift with just the ZL1 installed, the pad was too close to the rocker for my liking and I do not have skirts intalled. If you use just a floor jack, the ZL1 should be sufficient.
