2015 Z06 ...want to add exhaust question
Was considering adding exhaust...Borla,etc. do not want to void warranty.
So I won't be adding tune with it.
Can someone tell me if the NPP option can work with headers. Or are you always open. Sometimes I like to quiet it down in some seceniros.
Former Vendor
Adding headers and X-pipe will not affect NPP functioning. Now if you change catbacks then depending on what system you go to it can be affected.
We use ARH longtubes with offroad X pipes on the C7Z's.
Now since you dont want to tune i would just run a Corsa X pipe to delete secondary cats. That way you have no check engine. Then change to a catback system if you want it louder than what the x pipe gives.
Perfect .....
