(Video) Dynamic Airfow Catch Can testing.
Supporting Vendor
Happy to field any questions this video brings up.
Challenge Series 1: Basic Crankcase Pressure Control
Challenge Series 2: 'Ebay' cans
Have a can you would like to see tested? Send it in!
No more BS, no more hollow claims, no more hype and deceptions. Major brand names preferred. #maythebestcatchcanwin
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
The following 2 users liked this post by David@MMS:
Dabigsnake (04-11-2017),
vettetwo (04-10-2017)
Can models that dont vent to atmosphere?
Do you have any catch can models that do not vent to atmosphere? I am basically trying to keep with the spirit of emissions compliance as best as possible while still having the increased benefits of such a system. Thanks!
Supporting Vendor
this still can support up to 1200hp fitting depending.
https://www.mightymousesolutions.com...lator-your-can
Awesome, and thanks! One last question. Do you happen to have any information as to how the stock Z06 engine is affected by coking? I have found some information on it being bad on direct injection engines (especially ones with boost) but cant find reliable information as to whether stock C7 Z06's would have the same issue. If it is an issue, would your catch can help reduce coking?
Again, thanks for offering such a great product and taking the time to answer questions.
Supporting Vendor
my advice is to pull off the lid and see if what you find bothers you.
-contrary to some here that find it no big deal to mop up the supercharger and call it good, remember you are only seeing the tip of the iceberg so to speak.
this video here has the lid removal in the first section
Supporting Vendor
no, crankcase pressure can be damaging.
as a wise consumer i suggest you make sure it is minimized for your application, to whatever end or product that takes you to.
i merely provided direct example of how a suction line does not always mean you are in crankcase vacuum
https://www.youtube.com/watch?v=Jl70sRRpibk
Your PVC adapter that replaces the factory PVC is the way to properly engineer a catch can set up for the LT4. Great job MM.
Supporting Vendor
GM can void your warranty for any reason they can come up with.
My advice if you are about to save a ton of money by having warranty work done, either take it to a place you trust to not screw you or de-mod, and keep the ball in your court.
Thanks for the support!
thunder hound@53 (04-14-2017),
thunderhound@53 (05-11-2017)
Supporting Vendor
If any of you guys have a brand name can I have not run I would be happy to bench test it (the flow test above as well as oil consumption efficincy and maximum capacity) add the data to my public library, and pay return shipping
Supporting Vendor
Supporting Vendor
Another record month! C7 sales action is steadily picking up. Thank you guys.
Supporting Vendor
new video added!
DavidC83 (05-17-2018)
Supporting Vendor
only can we use!
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
