Frustration of side skirts and the lack of them....
I've seen a number of posts where numerous members are looking to GM to offer up a retro fit kit on 2015-2016 Z06's to modify their supercharger arrangement to the 2017 design and thus help prevent, or minimize or eliminate, cooling system issues. Up to this point, the "don't hold your breath" response seems to be in order, regardless of what some people believe Tadge inferred months ago. My question is from the same church, but a different pew. Probably most owners know of the "stone blasting" the rear brake intakes (and beyond) take on a C7 Z06 unless, it appears, the car has side side skirts and probably splash guards...but without the side skirts, there is nothing one can do to prevent this phenomenon. Chevy/GM must have gotten the message regarding the magnitude of this problem, especially for those of us owners who didn't realize the need for side skirts and weren't told by the dealer to add them on the order. Now, for 2017, order a 2017 Z06, any flavor, and side skirts are standard....gee whiz, go figure! So has anyone without the skirts, who has experienced the terrible experience of the stone blasting, been able to get some kind of deal from his dealer in acquiring the skirts after they have taken possession of their car....not free, but perhaps the same price as they would have been if ordered with your new car? This whole issue is a huge PIA and had I been told that the car needed these skirts, I would have added them to the order! Thanks for any help in this area!
http://www.gmpartsdirect.com/chevrol...position=right
http://www.gmpartsdirect.com/chevrol...&position=left
These parts are cheaper than the factory price.
I have the splash guards only. I have zero impacts back there. To have one or the other I would choose splash guards as they protect width and length. Side skirts are for length (underside kick ups) only.
427bob (04-17-2017)
I don't know where you live and the road conditions in your area, but in my area, splash guards alone do not do the trick...the stone blasting is subdued to a point, but far from being eliminated. I've spoken to several Z06 owners in my area of PA, where we still have anti skid (crushed stone) on the roads, and they have been successful at virtually eliminating the "blasting" by having side skirts and larger splash guards. Wish I could go along with what you're seeing. Besides Oreilly splash guards, I've additionally Xpeled the brake duct areas and I'm still getting nicked by the stones...in only 200 miles! Unfortunately, it seems the side skirts are my last resort.....
the roads here suck. Gravel and Sand everywhere. My Buddy refused to put them on. After the blasting started he folded. Now he also has no (additional) impact marks since the install. I cannot take the credit as I learned from others here.
there's a post where the pic is shot from the rear brake duct. It shows where the mud guards have to be. As for height. It's about a 2x4 flat and one finger width roughly. This way you cannot see the tread from the rear either. I posted a quick vid of how I did mine. They work 100% better than all others and the rocker extensions aka side skirts of any kind. $10.99 at advanced auto figured that out after I purchased mine from amazon for $16.99.
I also have xpel installed in key locations as well as above the mid quarter panel exactly where the blasting occurs. Now it's basically a waste.
http://www.youtube.com/playlist?list...uACqri25mktPUP.
16/C7Z, I understand what you are saying and I too, have the Oreilly splash guards...and they are terrific, the best deal on the 'net for any Z06 splash guards (see picture). My question to you is your stated measurements. You said laying a 2X4 flat (which I would guess means the 4" side is flat on the floor) so the 2" side is vertical...that would be around 1 7/8" on a standard 2X4....add a finger width, probably 3/4", so your distance from the road to the bottom of the Oreilly splash guard is approximately 2 5/8", give or take a wee bit. Mine are set at 3.5" above the ground area, so that's where the issue may be. As mentioned, I've got the rear quarter panels (including the brake ducts) and the lower rocker panel between the front and rear wheel wells, XPEL'd, and I am picking up some stone chips at 200 miles on the car after that work was done. My info on the Oreilly's was to be sure to have an absolute minimum of 3-3.5" off ground level because they could get tortured/damaged from speed bumps or other such things, even if you would crawl over them at an angle....and that is why I have mine set at 3.5". Maybe my info was wrong...what's your experience?
yes, at 3.5" you're an 1" to 1.25" high.
I came up with that height due to SEEING the tread with the guards against the car before install and again, realizing that if I can see tire tread fron the quarter under the car the debris can still be slung uo there. So lower and wider is key. Especially the lower part.
not trimmed, basically the size. You'd have to mount them lower them in the wheel well to get the 2.5" that he is talking about. Then you risk the possibility of ripping them off or damaging them if you went over an obstruction like a speed bump. That's why it looks like side skirts coupled with the guards are the only cure. That's what many other owners are saying.
Standard on ALL 2017 Z06 and GS models. See http://www.corvettemuseum.org/wp-con...eringGuide.pdf and you will find it near the top of the first page. They are referred to as molded rocker extensions.
I had ACS skirts installed on my 2016 Z06 before it left the museum.
Received 8,926 Likes
Bill
I would like to know where these other "know-it-alls" get their Fake News!!! haha!!!
You are correct! I have the base model 1LZ that I bought last week. It did not come with the side skirts. I actually called the GM customer line (that was a waste of time), and after 2 dum-de-dum's BS'd me around for 15 minutes (most on hold) they connected me to my dealer. Then I sent a text to a friend at Bowling Green and he confirmed to me that the base car DOES NOT get the side skirts.
See: http://www.gmfleetorderguide.com/NAS...ehicleID=20103 and also go to the Chevrolet site to build a 2017 while it is still up. The build photos will show you the shorter rocker extension (i.e. skirt) that comes stock on all 2017 Z06 (and GS) and if you add one of the ground effects packages you will see the longer rocker extension/skirt that comes as part of that package. I think the confusion you are getting from the dealer and Bowling Green is the difference between the smaller skirt which is standard for all trims and the longer skirt which comes with the ground effects options. You can also look at the compare trim levels on the Chevrolet order site and you won't see the rocker extension/skirt listed on those screens because it has NOTHING to do with trim level.
And on edit, take a look at this 1LZ at MacMulkin with no optional ground effects which has the stock skirts that should have been included with yours. Call one of the big dealers to get the correct info: http://www.macmulkin.net/VehicleDeta...-NH/2889069193
Worst noise I hear is coming uphill onto street over a raised curb leaving my buddy's shop. It's a little crrrrrrrrrrr' sound. They look none the worse me if they ever do it'll be a quick run the store, trace and install again.. done
