Z05 top speed of 200?
Z07 equipped C7Z top speed is 186 mph. I've done it in mine few times. It kind of hits a brick wall after 140mph. Stage 1 convertible Z06 with the top down did 202mph on the autobanh. Theres a video of it somewhere @ Youtube.
GM said aero 3 was 186, I think Aero1 was 192 or 195. C6 ZR1 was GM claimed 205.
New Ford GT claims 216.
z51vett (04-23-2017)
caddy ad claims 200mph out of their 4dr sedan with 640hp
Not like most people are up in that range often anyway.
Lavender (04-23-2017)
#33
Johnny Bohmer has the NASA landing strip for early June. There are a few spots left. I was going to go but have a schedule conflict. It isn't cheap but you have 3 miles total. I think up to 2.2 miles for go and .8 miles for whoa. There is a stock C7 Z06 Callaway that did 204 in Mojave in 1.5 miles. I think 2.2 is enough to top the C7 Z06 out.
#34
Received 3,109 Likes
Finalist 2020 C7 of the Year -- Unmodified
#35
#36
And I believe that is a true claim. The CTS V isn't designed to produce as much downforce at speed as the Z06 even without its stage 2 or 3 aero so it will be faster in a straight line. It will also be faster at exiting the track if it tries to match speed with a Z06 through a high speed curve
#37
Received 1,817 Likes
Doesn't every production line engine come out a little different? Or is that a thing of the past?
And wouldn't a lot depend on factors which might cause the engine to reduce power, like pulling timing if detonation is sensed? It's hard to believe that this engine could operate for 1 or 2 minutes straight at full power, without becoming more susceptible to detonation. Aren't some people logging timing being pulled in just quarter mile passes?
I haven't read of any standardized protocol that's used for determining top speed, and it seems that things like air temperature, air density, fuel octane, and even tire pressure might make significant differences.
#38
Most all GM engines are SAE rated HP so the variances are very small. At ~ 200 MPH 5-10 HP won't make much difference, like maybe 1/2 MPH max in a C7Z.
Most events that time for speed do it with a set of laser beams separated by some distance so it is an "average" of that speed over that distance, not a speed at one point. Yes, weather conditions make a difference. Mojave is at 2600' and the density altitude is frequently about 3000'. I'll be doing a standing mile event in a couple weeks where the altitude is 6400'. While the air resistance is less at altitude, the N/A engines make much less power. On FI cars it depends on how the control system is set up on how much power is lost.
