Now Available - Granatelli Adjustable Toe Links with AMT locking plates
Supporting Vendor
Now Available - Granatelli Adjustable Toe Links with AMT Locking Plates for all C7 Corvettes
AMT Motorsport is proud to have partnered with Granatelli Motorsport in offering their rear adjustable toe links for the C7 Corvette. As anyone who's been under the car knows, the stock toe links are adjusted using an eccentric cam much like the factory control arms. However this cam makes it difficult to achieve finite toe adjustment and like the rest of the eccentrics are prone to slipping when driven hard on track
Granatelli has solved this problem by offering a bolt in replacement for the factory toe links. These toe links are adjusted turnbuckle style by simply twisting the shaft, like every other toe link known to man. This makes for fast and precise toe adjustments at the rear of the car. Rods are black anodized 6061-aluminum, with heavy duty teflon-lined heim joints on either end. The tapered pin that inserts to the GM spindle is 4130 steel and phosphate coated to protect against corrosion
Finally, AMT improves upon the concept by eliminating the factory eccentric all together. Even with the huge range of adjustability the Granatelli toe link is still installed with the factory eccentric in place. Knowing the eccentrics can slip we instead ship our toe links with black anodized 6061 aluminum plates to be installed in place of the factory eccentric. Grade 10 metric hardware is included to replace the factory hardware. Coupled with the AMT C7 Camber kit, you've now eliminated all the silly eccentrics on your C7 Corvette and can pound around the track til your hearts' content without worrying about your car slipping out of alignment
Features of the Granatelli Motorsport Toe Links:
• Turnbuckle style link allows for precise, fine-tuning
• AMT locking plates and hardware eliminate factory eccentrics
• .875 diameter 6061-t6 billet rods
• Heavy duty 5/8”-18 Teflon-lined chrome-moly heim style rod ends
• CNC machined 4130 Carbon Steel tapered pins are black zinc plated.
• Dramatically increases vehicle stability at speeds
• Improves handling
• Designed to be a direct bolt in and fit
• All necessary hardware and instructions are included.
Pricing for the Adjustable Toe Links with AMT Locking plates is $245.25 plus shipping.
Follow THIS LINK to order from our website.
If anyone has any questions at all please let me know and I'll answer all that I can. Thanks for looking!
Supporting Vendor
I hear ya. But look at it this way, at least you're not spending absurd money on a 14 year old C5 racecar. Pretty sure every dollar I spend decreases the value of the car three fold!
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
This Toe links works great! When you dial in a lot of negative camber to the rear of the C7 it is virtually impossible to get toe adjusted in stock form. The way its built appears it will hold the toe in high G cornering much better too.
We have the AMT alignment kit and stud-shim kit on our Z06. No more shifting eccentrics. We will be testing some big camber numbers this track season soooo looking forward to it.
Hey those MPSS non ZP's ride very well and stick much better than the cups when cool.
Supporting Vendor
I don't have any actual real world experience with fighting a dealer over warranty claims, but everything I hear and read always says if they're going to deny you coverage they have to be able to prove the offending part caused the failure. I don't know how a tie rod replacement could cause anything to fail, least of all a drive train.
These are great toe links!!! But they use the stock eccentric on the cradle end.
Mark's plates should take all the worry out of your toe alignment slipping!!
Great stuff!!! I got these in Nov last year, and the "tie-rod" type adjustable toe link makes adjusting toe very easy!!:thumbs
Bob
Below is the OE toe link. You can see it's just a solid rod. The entire toe alignment is done with an eccentric washer - it has a very limited range of adjustment, is difficult to make adjustments to toe (especially to fine tune it!), and is susceptible to slippage:
And below is the right rear of my car with the Granatelli adjustable tie-rod type link. At the very left end you can just make out the OE eccentric behind the stabilizer bar bracket. I need to replace that eccentric with Mark's plate:
Bob
LOL. Come on guys. You bit, hook, line and sinker. I was bored and having read all the stupid posts of people asking if non issues will void the warranty I couldn't resist.
As I know several of you that gave a patient response I' m surprised you didn't let me have it with both barrels......
Rick
Rick
Love the product but just wondering on this claim - dramatically increases vehicle stability at high speeds.
Toe adjustment is a PITA but I've never had them slip or anything. And surely they aren't slipping constantly.
The heim joints are nice - but is there a significant amount of flex in them?
Supporting Vendor
I was initially just going to carry the product, but after talking to MadDog he told me he's had the toe eccentrics slip on his own car, so they can and do move. Reason enough for me to make a simple plate to eliminate that possibility.
The heim joints don't flex, they're solid pieces. Where are your concerned that they would be flexing?
As far as flexing, I was trying to help justify the claim of much more stability - thinking the OEM bushings could compress a bit.
Rick
Rick
Didn't know your a fisherman? Funny I had to read it a few times over.
Pay back is a bitch
Supporting Vendor
Thanks all you CF members for your support on this product! We're on to our third shipment of parts now from Granatelli, and they'll be arriving Wednesday. Please let me know if I can answer any questions on this or any of our other offerings.
How do you adjust the length when it's installed? Just loosen one jam nut and turn the bar itself? Or do you have to disconnect one of the bolts/nuts on one end?
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Loosen both jam nuts and it turns just like a normal toe link adjuster you would find up front. A crow's foot and extension makes getting to the outer jam nut easier.
spearfish25 (02-06-2018)
Supporting Vendor
Bump for to get some folks to follow the link to our new website! I've just ordered 10 more sets of these from Granatelli and have one left on the shelf ready to ship. Also got about 40 sets worth of locking hardware so if anyone needs to add locking hardware to Granatelli links you may already have we can do that too!
Locking hardware only for toe links
