Boostane vs Torco test results
I would read their sites on what they contain.
Again, I like cleaner plugs. You know residue can not be good for rings, cylinder walls, etc.
Received 2,379 Likes
log your knock sensor voltage if you want to measure knock activity (with knock retard pid also).
logging only knock retard or total knock retard on these cars can be very deceiving as many times it is not induced by actual detonation.
However, I googled for images on the internet of what Torco does. It apparently puts an orange residue on engine parts, and there were a lot of pictures that all show an orange color - similar to this one:
That may not be of any concern at all, but Boostane says it doesn't do that.
Are there long term affects to utilizing these octane boosters? Outside of the orange coating as pictured on the torco apps? Will the 17s adjust to a 100 octane tune? Great data, sorry for the noob questions
Received 8,926 Likes
I've only mixed a total of about 10 quart bottles of Torco in my car at the last couple of track events, and I haven't pulled any plugs to see what they might look like.
Bill
2017 C5 of the Year Finalist
St. Jude Donor '08
Bob, how do you ensure you have a consistent mix at the track? I usually fill up after two 20 minute sessions although the tank is between 1/8 and 1/4 full I don't want to run out after several laps of the third session (especially 2 miles from pit in). I assume this is much cheaper than filling up from the race gas pump ($8/gal) that is next to the street gas pump ($3.50/gal)?
Bill
Bill
I add some Torco, then some gas, then the remaining Torco, then more gas. Depending on your mix/ratio, add accordingly...
With supercharged cars, especially my blownc5, I like to stay close to a half tank or better on road course, just safer in my opinion/experience when asking for LOTS of fuel when creating G-forces...
I've got the same built motor stroked 418 LS3 in my Supercharged C5 for the last 6 years. If I'm behind the wheel, it's being driven HARD! I've been running Torco in everytank full, and have not had a single issue from any build up...
some folks think that if some is good, MORE is better. Also, those plugs have other issues going on as well...
Hi Bill
Well....I've been using these - a 2, a couple 5, a couple 6, and a 14 gallon tank!! You can see a bottle of Boostane and my measuring cup on the tonneau cover:
I carry a couple of those jugs in the bed of the truck and several in the trailer. I keep them empty until I get close to the track, then fill them up with 93 octane. At a multi-day event I'll take them in the truck when we go out to dinner and fill up.
Using the the Torco blending chart, it says 12 oz of Torco in 5 gallons of 93 will give you 100.5 so I used to put about 12 oz in the 5 gal jugs, maybe an oz more in the 6 gal jugs, and a 32 oz bottle seemed to be plenty in the 14 gal tank.
I haven't used the Boostane Pro yet, but you see on the can that it says 1 qt in 25 gals of 93 will turn it into 101 octane. So my 5 gal jugs would need 1/5th of a qt, i.e., 6.4oz. So, I figure 6 oz plus a drip in 5 gals should give me 100 octane, and I'll ratio that up for the other jugs.
Bottom line - I'm doing most of my refueling at the track from my gas jugs lately. It's easy to add the correct amount of octane booster that way.
And it looks like with Boostane I'll only need about 1/2 what was required with Torco.
If I start a track day with the car filled up, and burn maybe 11-12 gals per session (the dang Z06 SUCKS DOWN the fuel!! I'm getting 3.8-4 mpg on the track!!), my jugs should take care of me for a day.
Bob
Bob
Received 4,707 Likes
Can anyone explain to me what either of these products may do to the factory emission system/catalytic converters on a stock C6?
Hi Bill
Bob
Bob
Bill
I've only run 4 events with the C7. Two with the stock tune and 93 octane pump gas: at NCM VIR HPDE last year; and Daytona in Oct.
Then I got the 100 octane tune in about Nov and drove two events here at Daytona in Dec and this month with 100 blended gas.
I also did a 1/2 mile WannaGOFAST event in Jan with a 100 octane blend, but it was my first (and probably last!!) drag race type event I've ever run, so nothing to compare it to.
The first couple HPDE's with regular 93 octane I was getting used to the car and not pushing it real hard. I've been getting progressively more aggressive as I've gotten used to the car, so the last two events with the 100 octane tune and 100 octane gas blend I've pushed the car harder.
So...it's hard to tell if there is any difference in performance between before/after the 100 octane tune, or if it's because I'm just ready to push the car a lot harder now.
I haven't logged any engine parameters other than what Cosworth Toolbox shows. But I have a couple devices that I can use to check knock, and I may try to log knock at VIR the end of June (my next event). Unfortunately, with the 100 octane tune, I'm kinda committed to running 100 octane at the track, so I really can't fuel up with a tank of 93 for a session to see the difference in knock between the octane levels.
Bottom line - I don't really know how much the 100 octane tune might be helping performance of the car. I've been getting used to the car and driving harder at the same time I got the 100 octane tune, so maybe it's a combination of both!
However, the car does run really strong and smooth at WOT with the 100 octane tune and gas blend.
#33
"Do not use fuels with any of the following conditions; doing so may damage the vehicle and void its warranty: Fuel containing metals such as methylcyclopentadienyl manganese tricarbonyl (MMT), which can damage the emissions control system and spark plugs."
TORCO contains MMT which leaves the distinct orange deposits as shown in your picture. The manganese is the deposit seen and it flakes off causing excessive wear to piston rings and pistons. If your warranty is intact and GM sees these deposits following an engine failure, it won't be intact any longer. Is it something to be concerned about? I can't answer that question since I won't be the one paying for your engine and I can't say if you even have the orange deposits.
MMT works exactly like TEL (Tetraethyl lead), they are both organometallic compounds that work by modifying the pre-flame reactions in the combustion chamber to prevent an improper flame from developing. The short version is it increases the ignition delay which is where people get the "Old Wives Tale" of higher octane fuels burn slower...the octane rating of a fuel does not correlate to flame front velocity. Ignition delay as used in this context does not refer to the time component, it refers to the temperature component...it increases the temperature at which it allows the flame front to propagate. Increasing the amount of MMT or TEL concentration is a case of diminishing returns, you get to a point where you see very little increase in octane rating with each additional gram of MMT/TEL. For that reason, there is no 32 oz can of anything that will raise 93 octane fuel to 100 octane...even TORCO proves that with an "independent" test where 91 octane fuel increase to 96 octane. In reality, you can expect to see a 2-3 octane number improvement with the best octane booster and TORCO is one of the best if not the best. If Boostane isn't using MMT or TEL, maybe they're using Ferrocene but it leaves a reddish-orange deposit from the oxidation of the iron component. The iron-oxide deposits also increases the conductivity of the spark plugs leading to misfire. The bottom line is if you want 100 octane fuel, buy 100 octane race fuel...then you know for sure you have 100 octane fuel AND your warranty stays intact.
#34
If your car wasn't pulling timing beforehand, then no amount of additional octane will improve performance (and in fact, will hurt it). This test might determine that you're not octane limited perhaps? But without something to increase octane demand, not sure what this reveals.
Ideally you'd want some scenario where you were experiencing knock counts, add an octane product, repeat the scenario, and have those knock counts (and accompanying retard) to go away.
I'm not ragging on you though, it's incredibly hard to measure octane. In fact a dedicated one-cylinder machine used to be used, might still be!
It isn't "incredibly hard" to measure octane rating, they use the same basic reliable CFR engine they've been using for ~80 years, and yes it's a one cylinder engine you can adjust the compression ratio with a hand crank while it's running. The study of the internal combustion engine was my minor at Georgia Tech and we had one of those engines I got to play with as the professor's teaching assistant my senior year. We also had an engine with a "window" that we studied flame front characteristics with a high speed camera...neat stuff.
#35
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
#36
how are you coming to that conclusion? You use LESS boostane and use MORE torco to get same octane......I'll give you one dollar and you give me 6 quarters because a qtr is cheaper than a dollar and you win what's the source?
#38
Any good deals for us forum members?? If you do promote/sell stuff here you'll probably need to be a forum vendor, but with a nice forum discount you might get a good amount of business.
If you just want to "answer questions" the moderators will probably let you hang out and tell us about the product - like blending ratios, etc.
Again, welcome aboard!!
Steve Garrett (05-02-2017)
#39
Hi - welcome to the forum and thanks for checking in!!
That being said, as a chemical engineer, I am happy to offer information outside of BOOSTane as well, i.e. octane ratings, ethanol, heavy metals, future of fuels, engine tech with regards to fuel, etc.
I know some of your initial concerns was cost and depositing. With respects to BOOSTane our costs comes primarily from the proprietary carrier that our team developed. As I am sure all of you know there are million ways to increase octane. Ferrocene for example is a very inexpensive way of doing so. However, ferrocene comes from iron, so as you can imagine this would lead to oxygenation. Therefore, we worked to develop a product that not only increased octane but did so reliably and sustainably, thus our carrier.
Our ability to keep active ingredients suspended indefinitely in solution allows for better/more efficient delivery as well as combating phase separation from varying densities while also stabilizing todays fuels from the hygroscopic nature (water absorption) of ethanol in our fuels today.
Anyway, feel free to fire away.
#40
I did pull a plug after trying both brands and that alone settled it for me but I also felt that Boostane had the better punch too.
