Sponsored by: GEM Motorsports
Katech Stage 3 C7 Z06 SN# 05
Old 05-09-2017, 03:23 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech Stage 3 C7 Z06 SN# 05
-Katech Stage 3 package (found here: http://katechengines.com/performance...-corvette-z07/)
-Lowering bolts
-Katech oil cooler kit
-Katech oil temperature sensor relocation kit
-Dewitts radiator
Vehicle is an A8.
__________________
Contact:
(e) zach@katechengines.com
Old 05-09-2017, 03:49 PM
mike123460
mike123460's Avatar
Over $10k for not even 700rwhp?
Old 05-09-2017, 05:14 PM
Katech_Zach
Look at the baseline. We are about 40rwhp lower than other shops' baselines.
Plus this is an automatic. We're making in the high 600s with manual transmission cars.
I can make the dyno sheet say 700rwhp if you want just the dyno sheet.
SterlingDrive (07-21-2017)
Old 05-09-2017, 05:32 PM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
Best to compare gross numbers, 650/650 to 800/800 (with headers). I have paid this much and gotten less from others. And it is from Katech. And includes additional cooling.
Old 05-09-2017, 06:14 PM
Bad Dad
Bad Dad's Avatar
Looks like a dependable kick *** build that can be driven daily, No meth correct?
jim2092 (05-09-2017)
Old 05-09-2017, 06:51 PM
randyn
randyn's Avatar
Can you also make the dyno sheet not show losing 75hp from 5500 RPM to 6500 LOL!
all kidding aside, why does it fall down so hard after 5500. Looks like something ain't quite right.
Just asking what is the choke from?
is it a fuel issue?
Old 05-09-2017, 07:38 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
is it a fuel issue?
I don't think you're reading it right. Torque falls off as you'd expect and hp stays about the same or climbs a little bit in that window. I think you were looking at torque and thinking horsepower perhaps?
Old 05-09-2017, 08:08 PM
randyn
randyn's Avatar
Umm..No!
The red pulls are the modded pulls..Blue is old/stock.
The "RED" HP falls from 5500 - 6500 pretty dramatic.
I'm sure most guys would love the explosive TQ, but I'm still wondering why the significant drop. I'm sure tuner can explain as they seem quite qualified.
Old 05-09-2017, 09:41 PM
davepl
davepl's Avatar
Umm..No!
The THICK red is the horsepower, not the thin red line. It drifts down maybe 50hp over the course of 1000rpm.
Or what do YOU see when you look at the dyno chart? I'm not seeing any precipitous drop in horsepower from 5500 to 6500. Like I said, maybe 50hp.
Old 05-09-2017, 10:08 PM
RJ-92
RJ-92's Avatar
475Ft/Lbs at 6500 is pretty impressive.
It's not about revs. This isn't a 1.8L VTEC engine. Area under the curve is what matters, and this combo makes a ton of it.
Old 05-09-2017, 11:01 PM
randyn
randyn's Avatar
The thick Red line is what Im talking about... at 4500 Rpm the motor is making just shy of 580 HP, increases to a max of 652HP at only 5500RPM. Then by 6400 RPM the motor has decreased in power to approximately 580HP.
Simple math 652-580=72 Sorry for my original sentence of 75HP.
Simple math and simple graph.
The amount of TQ was not my point, my question to be more specific was why does the motor lose power so rapidly after 5500. I think you can say the motor hits a brick wall at 6000...PERIOD!
The factory redline of the LT4 is 6500 and rightly so as you see on the Blue HP line that power is at 500HP at 5500, then "drifts" up 20HP by 6000 RPM then "drifts" down 20 to 6500 RPM. Hence, the 6500 RPM redline.
I think you can pick up that my first comment was a joke, then I simply asked why the drop. Jason will know!
My thoughts are fuel or probably the OE cam is too small for the increased airflow. I'm curious for the tuner's response as he is the brain behind the build.
I'm also curious if the rev limiter is lowered in the final tune is the power curve is lower in the RPM range (not to be confused with less over all HP and TQ)?
Old 05-10-2017, 08:08 AM
rflow306
rflow306's Avatar
Biggest reason is the blower, it is to small.
Old 05-10-2017, 09:30 AM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Default Sweet!
Very nice Jason.
Halltech has a ZR1 on order. Hope all the mods can be hot swapped over to that platform.
Jim Hall
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old 05-10-2017, 11:34 AM
Katech_Zach
No meth.
Old 05-10-2017, 11:38 AM
Katech_Zach
is it a fuel issue?
Here is a manual trans. Not quote as much of a drop off.
No fuel issue.
Old 05-10-2017, 11:42 AM
davepl
davepl's Avatar
I suppose I could plug this dyno curve into a simulator, but I might as well just ask:
It makes massive torque, but that torque does fall off with RPM quite a bit (as RandyN notes). Would it make sense to short-shift this car around 5500 or would it still be faster to hold the shift to 6500 I wonder?
Old 05-10-2017, 12:51 PM
Katech_Zach
Still faster to shift at 6500.
Guys, keep in mind what we're talking about here. Torque "falling off" from the tire-shredding 730rwtq at 3400rpm? The car is scary fast. I never think "oh man the torque is really falling off". LOL.
To Katech Stage 3 C7 Z06 SN# 05
Old 05-10-2017, 04:59 PM
randyn
randyn's Avatar
I never mentioned the TQ. I was talking Hp
speaking of TQ, your customer's car has almost 150lbs more than the stock car at peak, but at 6500 only 60 more. I would bet your customers car will run a quicker e.t shifting at 6000.
Especially a 8sp auto, but who cares. I just wanted know why the drop at 5500 and I think you answered.
thx
Old 05-10-2017, 05:03 PM
randyn
randyn's Avatar
Also, don't take my comments as an insult, I'm very impressed with your work!
Old 05-10-2017, 05:05 PM
davepl
davepl's Avatar
When you're talking about horsepower at a particular RPM, you are talking about TQ. The dropoff in HP you referred to is because of the dropoff in TQ over the specified RPM range. I was just giving you the benefit of the doubt. It's all the same thing - having both on the graph is just a matter of convenience, you only need TQ. HP is calculated, not measured.
Quick Reply: Katech Stage 3 C7 Z06 SN# 05
