Anyone change out the M7 transmission fluid?
Nearing the 15k mark and have not yet changed the transmission fluid. Has anyone tried a quality aftermarket synthetic fluid in the M7?
z51vett (06-02-2017)
500 mile fluid change
Yes for what it's worth, I changed my manual transmission fluid at 500 mile oil change just to be on safe side. Had opportunity to see drain plug as well and it looked clean with no metal shavings. I'd recommend for the cost to go and pay for it...under $190 if I recall.
Sr.Random input generator
Amsoil is best bought from Amsoil with their membership.
There are two fluids from Amsoil: Torque drive and the signature series ATF. When I asked Amsoil which one would be the best for heavy duty track use, they recommended that Signature ATF.
MSG C5 (05-15-2017)
Received 2,681 Likes
2018 C5 of Year Finalist
I just changed mine last week at 2600 miles. I used Redline D4 ATF 4 Qts. It wasn't underfilled. Fluid ran out when I opened the Fill Plug. Tranny fluid looked OK. Changed the Differential fluid also. It looked bad!!
I went with Redline in mine and it feels better than new.
Here's a quick DIY I typed up: https://www.corvetteforum.com/forums...d-service.html
I changed all my Z06 fluids at 500 miles, oil, trans (m7) and differential.
Used the recommended Mobil One and Delco products = cheap insurance.
Highly recommend changing the factory fill after break in asap.
I changed out the transmission fluid in my C6 Z06 TR6060(same basic transmission as the TR6070 that is in the C7; just lacking a 7th gear).
I found the Mobil1 DEX III synthetic ATF worked just fine in the Tremec manual transmission.
I tried the RP stuff and it made the 1st to 2nd gear nibbles worse than the factory fill.
Only use a DEX III ATF in the transmission.
I'm still running the factory fill(with over 50,000 miles) in my differential with zero problems. No after market stuff works as well as the GM rear end fluid.
TRT SR (06-02-2017)
yep....I changed mine at 700 miles.Had a very silver sheen to it.
It was an ez 30 min job.Takes a 3/8 socket and almost 4 qts.
Torque Drive is good and so is this.
\db2
\db2
TRT SR (06-02-2017)
Yes, a cheap fluid transfer pump works perfectly. Check the link I posted above which includes the exact pump I used that will screw right onto the bottles. They are readily available from Amazon or Harbor Freight.
TRT SR (06-03-2017)
Amsoil torque drive gallon 50 something fixed my 1 to 2 shift in cold weather on 12 Z06.
z51vett
Doug
z51vett
Doug
TRT SR (06-03-2017)
