Is upgraded heat exchanger necessary?
I was wondering if an upgraded heat exchanger such as the CPR unit would provide real world benefits?
Mine is going in today for their heat exchanger, LMR expansion tank and 17 lid. All in an effort to keep charge temps down here in the heat of AZ. E85 with fuel system upgrades next. Gotta keep it cool.
I also have a LPE 427 Maggie CTS-V and I took the Air to Air EOC off and noticed a big difference in oil temp over one hour normal driving.
To me the fix GM did was nothing more that expanding the existing cooling system by converting the tranny cooler on the manual to be part of the coolant system.
I've just recently installed DeWitt's Cool Kit on my 16 Z06. It really makes a difference, but mostly on the road course and highway driving. It helps at the drag strip, but not that much. In fact I'm reinstalling my nitrous kit tomorrow to use at the strip. We don't get enough time between rounds to fully cool down. In fact we run round robin...if you win you come right back into the staging lanes. I'm only going to do about a 50hp shot. Just enough to over come the heat soak.
St. Jude Donor '08
Contact forum sponsor Gspeed
https://gspeed.com/
They have packages that you can add to your car one at a time until you reach your cooling goal.
https://gspeed.com/
Supporting Vendor
On the stock Z we saw a drop of 14 degree's iat2 just while cruising around. under a wot pull 1st through 5th Iat2 was down 28 degrees and recovered back to it's natural resting temp 72 seconds faster. This test was done in 98 degree outside temps in the same day.
Our unit is 100% drop in w/ zero cutting of any plastics or lines needed.
We do keep these units in stock and can ship one out right away.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Evan Sanza (02-20-2022)
when we developed our HX we tested it on a 100% stock car, I wanted to make a unit that would help even a stock car, because if it would benefit them obviously a pullied car would see a better benefit.
Received 1,816 Likes
Supporting Vendor
it's a heat exchanger upgrade for the oem unit, it is able to pull out more heat from the system by using a denser fin count, increased size to hold more fluid, and a more efficient design overall.
Supporting Vendor
Supporting Vendor
Received 8,919 Likes
What is the IAT2 temp difference after 4 or 5 minutes of hard track driving vs one 10/12 second long short pull?
Bill
Bill
Supporting Vendor
