Does Dewitt's Radiator make a difference
Old Jun 3, 2017 | 08:52 PM
2017ZO6's Avatar
2017ZO6
Default Does Dewitt's Radiator make a difference
Does upgrading to a Dewitt's radiator help the z run cooler in spirited acceleration runs like drag racing?
Old Jun 3, 2017 | 09:02 PM
davepl's Avatar
davepl
The factory radiator is more than adequate for drag racing. Zero gains to be had.
Old Jun 3, 2017 | 11:25 PM
2017ZO6's Avatar
2017ZO6
Thank you!
Old Jun 4, 2017 | 09:00 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
What do you base this on? Did you try one?
The product has a five star rating with nothing but positive reviews. We have sold over three hundred units to date and the large majority of customers are very happy with the results. Sometimes people will read one thread and draw a conclusion. We use a much larger sample size and feedback from dozens of customers.
Old Jun 4, 2017 | 09:47 AM
Cordes Performance Racing's Avatar
Supporting Vendor
It works well, in az we do see a drop in coolant temps about 10-12 just cruising. Our customers that road race it helps them out immensely as it keeps the temps from creeping up. This time of year we do a lot of radiators as our average is 107 now lmao!
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jun 4, 2017 | 10:13 AM
2017ZO6's Avatar
2017ZO6
good to know researched results
Old Jun 4, 2017 | 11:10 AM
davepl's Avatar
davepl
Yes, I tried one. I tried the one that came in my car. I made no claims about YOUR rad, which I'd imagine is beyond adequate. Yours is also likely better than the factory rad for road racing or more demanding applications, but the question was about drag racing.
All I said was that the factory rad is adequate for drag racing. It is. In environments and applications where the factory rad isn't up to the task, then I'm sure yours is a fine choice.
Old Jun 4, 2017 | 12:09 PM
HighBeta's Avatar
HighBeta
Amat Victoria Curam
Dave, if I recall correctly, there was a recent thread from a poster who complained about his C7Z pulling power after several drag runs. Considering the slower climb in temps that a Dewitts provides, there might be some benefit here to OP. No, I have no hard data to post here ...
Old Jun 4, 2017 | 12:12 PM
Bill Dearborn's Avatar
Bill Dearborn
I agree. The DeWitts Radiator is a good product that provides added cooling capacity. However, added radiator cooling capacity isn't needed for drag racing as the engine isn't run long enough to get close to overheating.
Bill
davepl's Avatar
davepl
I can only speak to my own experience where, when running hot laps in reasonable air (mid 70s I guess) my car had returned to mid 190s by the time I got back to the staging lanes each time.
If you have a car or setup where you're NOT able to get your car to return to thermostat-controlled temp ranges, then that's a different case, one I can't speak to. Others maybe can!
Old Jun 5, 2017 | 12:08 AM
GSpeed's Avatar
GSpeed
Supporting Vendor
There is minimal power derating from coolant temp. There is HUGE power derating, on the order of 10:1, from blower cooling and a proper intercooler bleed.
TLR- Bleed the blower religiously if you drag race it.
As for the DeWitts piece, its good stuff. We use their largest radiators in all of our cooling systems with enough data to back up the pentagon.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
To Does Dewitt's Radiator make a difference
