Introducing ProTEKt Splitter Protection for the C7 Z06 and Grand Sport!
#101
Former Vendor
Are you running a different splitter than hoserdog?
Is the shape not quite right for your ACS splitter, or is it something that could solved by drilling some extra holes in the skid plates?
Hoserdog, would it be possible to share with us what was involved in installing the plates ont your ACS parts?
Thanks,
Mitch.
#102
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I can only assume what he added was the standard front splitter, basically a copy of the GM piece.
What ACS offers is a one piece splitter and under tray. This eliminates all your mounting points. This is the bottom as installed. All this holes you see are to access the mounting points in the splitter and get subsequently covered with included plugs (already installed in the photo). Each plug covers a 2-3" deep hole where the various rivets or screws fasten to the factory mounting points.
As you can see, there are no screws on the leading edge, or anywhere on the bottom side really.
#103
Are you going to do a version for the C6 ZR1 style front splitter? Sent an email never heard back about this.
Thanks.
Thanks.
#104
Former Vendor
We looked at the C6 ZR1 splitter, and the way it is constructed doesn't allow us to mount a plate to it, so we won't have anything that works with the splitter in place.
We do have a plate kit that will fit, but requires the removal of the splitter to run it., which is super practical, but most of the ZR1 guys want to keep their splitter.
https://www.corvetteforum.com/forums...t-and-z06.html
As well as a super durable splitter, that will bolt onto the stock splitter mounting holes, but is more of a race/autocross part, as it might not have a refined enough look for a typical street car, as well as being a bit more difficult to install, as in needs some shimming and adjusting to get it just right.
Thanks,
Mitch
#105
Former Vendor
I think he mounted it by drilling new mounting holes in the undertray portion of the splitter, mounted the plates, and then drilled new holes in the plates for access to the fasteners that hold the splitter to the bumper.
Since my parts were originally designed for the OEM parts, I think that there is a little bit of DIY to get them to work with the aftermarket stuff, but I also get it that not everyone is comfortable drilling new holes in a brand new splitter!
Thanks,
Mitch
#106
You could definitely drill through, but would be next to impossible to get to the backside for any sort of fastener or jclip. Not sure I would trust a self-tapping or simple screw to stay in for the level of track abuse my car sees, but it would probably be perfectly fine for a street-driven vehicle.
No worries, at some point I will likely have to replace this in the future (if not due to damage from not having your plates) and will take the into consideration with my next splitter.
#107
Former Vendor
1. With the splitter upside down on a workbench or floor, place the skid plates, and drill the holes in the splitter to mount the skid plates.
2. Using bolts, nuts, and large diameter washers, bolt the skid plates to the splitter.
3. Drill the skid plates to match the existing holes in the splitter where needed, so you have access, the same as before the plates were mounted.
4. Install the splitter to the car using the normal procedure.
Not having done an install on the ACS parts myself though, there might be a reason that won't work, that I am not seeing in the pics.
Thanks,
Mitch
#108
Former Vendor
Were you able to use it? I haven't gotten any return requests lately, so I'm hoping that it worked out for you.
Either way, we offer refund of the full purchase price, if the parts come back in new condition that I can resell.
PM me for return info, if you want.
#109
fleming23,
Thanks for checking on it though! Unfortunately, my brand new splitter already has a nice scrape on the bottom and the car has not even been driven on the street yet. Not sure if I did it or the detailer did it at his shop but your plates would have prevented it for sure.
#110
Thought i'd drop in and let you know that your splitter protection kit worked perfectly with the Caravaggio Stage 3 front splitter and under tray. Its been on a couple of weeks and has already saved my splitter once.
ProTEKtMitch (02-21-2018)
#111
Former Vendor
Thanks!
Yea, I feel like that how it goes with this product. You might drive for a couple months without really needing it, but it only takes one hit to ruin the splitter, and then suddenly you are glad they are there to provide some protection.
#112
Former Vendor
Guys,
Just a little note that the ProTEKt splitter protectors are now available on Amazon Prime!
Probably not a huge thing for you guys, but to have Amazon warehousing our parts, and doing the fulfillment, is a pretty big step for our little company.
george vee (02-11-2018)
#114
Not sure if this was covered. Does this kit REQUIRE a skid plate? I had the Stage 1 splitter with NO undertray but ordered the C7 Carbon Stage 2/3 with winglets. Until the aero kit comes in and I can see it personally, I am not sure if the C7 Carbon has a flat bottom on the front splitter itself to attach the protect kit. Does anyone know?
#118
Ordered through Amazon on Sunday. Rec’d shipment today! Cannot wait to pick up Z06 at Museum and get this critical part installed. Thank you for developing!
#120
Any known good configurations with aftermarket Z06 splitters? I'm on the fence with a stage 2/3 splitter but this could push me into doing it.
