Taking aero to the next level with a TIKT splitter #becauseracecar!
Katech_Zach (07-21-2017)
So it includes the oil cooler? I assume it includes the grill as well?
Is the splitter extension easily removable to get the car on and off a trailer?
Premium Supporting Vendor
The undertray is removable by taking out the 13 perimeter bolts on the bottom, the 4 bolts/nuts in the center support, the 2 bolts that go into the undertray support brackets, and the cable pin. It's not a big job, but I wouldn't want to do it every time I had to load into a trailer. My trailer has the fold out aluminum ramps and if I jack the nose of the trailer up I can get the car in no problem.
Poor-sha (07-21-2017)
[QUOTE=Katech_Jason;1595190860]It would hurt top speed in a drag race, half mile, mile or top speed type of race. For high speed stability 150+mph you may need something, but this is probably too much.[/QUOTE
OK. THANK YOU
OK. THANK YOU
Tikt Splitter
With Tikt Aero package splitter and cooling system
They will never get hot anymore.
Green beast has done:
two races each 30 minutes, result 2 victories
Oil and water always perfect
Oil Max 122°
Water Max 93°
Oil Max 122°
Water Max 93°
thebishman (07-22-2017)
What's interesting to me is that this "Slim Green Beast" is running with both the Z07 factory street rear air-spoiler setup and the for track "wing" spoiler. It has been my understanding from reading, not experience, that to run the "wing' type one should remove the "dove-tail" type as far more down force than needed would be created turning into unnecessary "drag" on the car???
Supporting Vendor
Received 2,316 Likes
Need a side view of this. Need better pics of car man...I feel like I can't SEEEEE it. That splitter is perfect for the car and body line, etc. Looks like a factory designed upgrade piece. Serious bitness.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
That truly looks badass, Jason!
#33
