DSC controller questions to owners
Has anyone installed the DSC controller in a recent build 2017 Z06 with Z07 package?
Was the improvement significant?
Those of you who did this install what USB cable did you use? Where did you buy it? How did you seal it up against the elements?
Received 2,379 Likes
I don't have the USB cable installed at all. I did install it on my 2016 before WiFi was available but now I don't feel it's needed.
I can definitely feel the difference on my 2015 with considerable reductions in lap time. I purchased part # 087874 cable at Micro Center. 3' USB2.0 A0MINI-B for $14.99. Placed a very small zip lock bag over connector and tucked the cable back down into the area behind the clutch/brake cylinder reservoirs near the left front fender air intake. May possibly keep it a bit cooler there. The 3' cable only allows you a foot or so of extension beyond the engine bay, so you definitely can't reach the cockpit, but my wireless mouse will talk to it thru the windshield and I can set the laptop on the cowl to see it. Imagine you could go with a 6' cable to let it reach cockpit but that seemed like a lot of cable to have to coil up under hood.
You may also want to tape or somehow secure the mini USB end into the DSC controller so it does not pull out. I snipped a hole in the DSC provided port rubber plug, inserted the mini USB through the hole, then gaffer taped the plug and cable in place. Don't know if moisture could be an issue, but this will help mitigate it a bit. My only suggestion to DSC would be a better waterproof plug set up to securely lock the mini plug in place and make it waterproof.
One last note, my thanks to Bish for coming to my home to help me through the shock zeroing procedure. The Bish is tops!
thebishman (07-17-2017)
Bish
I live in North Alabama and I "think" I have identified a shop in Nashville that can do the proper alignment.
#33
Bish
why1504 (07-19-2017)
#34
Search your regional sub-forum here for recommendations re: 'speed' shops that can do excellent alignments. Another option is talk to owners in other car clubs such as the PCA; lots of those guys are track hounds and will know where to go to get great alignments. You can purchase the rear caster adapter pretty cheaply and take it with you which is what I did with my local independent shop.
Bish
Bish
thebishman (07-19-2017)
#35
It's like putting your suspension in God mode.
#36
Quick questions.
After i "read all" when I try to close it out the program it asks if I want to save. Do I save it or just close it? Also, same for when you "zero" the ride height sensors. Once you do that, do you need to save and close the program before removing the USB?
Final, I have the C7 module but defaulted to the Porsche 9x1 when I first "read all" and it seems I have all the cars and it's tuning software. Is this normal?
#37
Quick questions.
#38
Quick questions.
Also, you have to set the board to the specific car. Its interesting that yours sets to the 911; mine always defaulted to the C7 Corvette. Again, I'm sure you'd need to 'Save'.
Also, you always need to 'Reset the Board' before you make changes iirc.
I'm not an expert; hopefully someone else will also chime in soon, but the above is what I've always done and what I believe is written in the instructions.
#39
Thanks Bish. During the initial set up process where the tutorial asks you to select "read all" and run the process is where I noticed it was set to the Porsche. So I did the read all process of the Porsche then the Corvette however when I close the program out it always asks do I want to save. Problem is I didn't do anything but select "read all" and run the process so I am not sure if I need to save that or not. Ie. I don't want to over write anything by mistake.
I assume when I plug in the module to the actual car it will go to the corvette tune so let's see. I just don't want to run the Porsche tune by mistake.
#40
Quick questions.
If you previously did a read all or did a read all and modified something and rewrote the controller you are saving the current settings in the controller.
If you are using the USB method of connection once you change the car designation to C7 it remembers it in subsequent uses. If using the WiFi it does not seem to remember what car you are using it on although it doesn't seem to matter as if you are lucky enough to have a read all or write all successfully complete it seems to be correct when compared to a stored in your computer pdts file which is directly loaded to the DSC tuner software.
I find it useful when doing a write to the controller to then do an open and load into the DEC tuner software a different pdts file. You can then do another read all and check to see what you thought you wrote to the controller is actually there.
