Official Z06 Problem List
#241
I have a 2017 Z06 in La Quinta CA (near Palm Springs) and the A/C keeps us cool as can be at 120 degree outside temps. Seat coolers are about as effective as our 2018 Audi Q5 and our 2015 Cadillac SRX. Don't see much difference.
Fastmikefree (08-20-2018)
#243
Dealer called this morning and initially said that the motor tech said this was normal. Then 30 minutes later called back and said the tech would not certify it and sign off on it until he could do a complete inspection. That may be done tomorrow.....
7/10/18 - Dealer called today and said the motor expert "heard" the noise but would not be concerned with it. They "made a note of it" and will send the car home. "If there is an issue in the future" we will look at it again. Basically saying in so many words to drive it until it really breaks and hope at that point it's still under warranty. I don't know whether to be worried or relieved. I really wasn't looking forward to the dealer tearing the motor down, but then again, I'm not at all pleased with having the thing tick loudly for 20 seconds every cold start up. I'm really disappointed that I even have to worry about this from now on, as long as I own this car. It was supposed to be my dream car, once in a lifetime opportunity.
#244
7/23/18 - Took it to a second dealer for another opinion. They said it was the vacuum pump running a diagnostic and the noise could by cycled off and on by turning that pump on and off. I took the car home and the next morning researched the issue. I called the dealer back this past Monday and set up another appointment, basically called bullshit on that answer. It's a very clear valve train tap on cold start. So I'm getting another look on Monday.
Kenpokev (08-25-2018)
#247
I guess this is more of a question/inquiry since I’m not sure if it’s actually a problem. Car made a moaning/groaning noise after I shut it down aftera quick ride (about 10 minutes). I googled and only thing I found was this:
https://www.corvetteforum.com/forums...-warms-up.html
The situation was different since this wasn’t during warm up, but rather after the car was turned off. I’m guessing it’s from the dry sump system but not sure if it’s even problematic. Was fairly subtle but both my wife and me heard it, lasted maybe 10 seconds.
Many thoughts?
Many thoughts?
#248
#249
Seat adjustment memory
2016 Convertible Z: Sometimes the memory seats work sometimes they don't. I'll go out and run errands and shut the car off, open the door and the easy exit works fine for a time or two. Go to the next stop and the easy exit feature doesn't work. Same when I go to start it up: sometimes the seat and steering wheel will move into correct position and sometimes they won't. Haven't had time to take it to the dealer.
#250
Figured I would add to the list. Had a small coolant leak on my entirely stock 17' ZO7. Coming from the very front of the motor, unknown specific area. Took to dealer, they said it was a cracked thermostat housing. Replaced and fixed. Come back home, car smells of coolant when I get out of the car in my garage again. Wait a few days, coolant droplets on the ground again. Will be taking it back next Tuesday as it is a minimal amount of coolant.
#251
I guess this is more of a question/inquiry since I’m not sure if it’s actually a problem. Car made a moaning/groaning noise after I shut it down after a quick ride (about 10 minutes). Was fairly subtle but both my wife and me heard it, lasted maybe 10 seconds.
Many thoughts?
Many thoughts?
The following 2 users liked this post by Oldfart01:
froggy1140 (05-28-2021),
Thomasmoto (08-29-2018)
#252
2017 A8 Z07 4900 miles
1. Paint issues on both fenders and front bumper next to the headlights. - both repainted
2. Front bumper paint issue came back - paint touched up
3. Front bumper paint peeling again - pending taking it back
4. Brakes Worn Service Soon warning came on - they said the sensor needed resetting
- They reset and it came back on soon as I left lot. Back in for fix
5. Rattling noise coming from rear hatch - pending them locating the issue
6. Carbon Fiber Dash is starting to warp/unstick - They ordered new dash, pending arrival and replacement
I've owned two C6 and a Stingray before my current Z06. ZERO issues with those
i still love my Z but this is getting silly
#256
#257
#4, is not a resetting issue. The sensor is likely cut.
#258
#259
2015 Callaway Z06. M7.
Have owned it approx. 2 and 1/2 years. In the first few months, one of the front mag shocks started leaking. It was replaced under warranty - easy in/out of service; took about 45 minutes.
Other than that, car has been bullet-proof. No issues, no squeaks, no rattles. Just basic service - oil changes, one set of new tires.
Car is a blast.
Car is a blast.
If you OWN or have OWNED a Z06 that experienced more than MINOR issues
Please list year of the car, A8/M7, Z07 package/Stage and your location, Briefly list Issue(s) , if still occuring, dealer resolved ( how many fixes involved) , buyback/ lemoned etc.
Please confine your replies to the Subject and please no bashing. This is an information thread, have requested a sticky so we can monitor issues.
Very important dimension is, do you track, auto cross or the like. Reason being, yes your parts are going bust if you do that. Actual race cars have to change brakes and tires every event, and other things break constantly with drive train abuse.
I have a 2015 Z06 with 2900 miles and no problems, but I also don’t track it. I spirited drive it on weekends if weather is sunny or not raining.
The car is perfectly silent when touring and screams when you’re on it! The Mich Pilot Sports grip nicely from a 10mpg roll, but needs different digs for 0-60 runs.
#260
djnice (09-22-2018)
