Safe way to get 700RWH
Do you have long tubes?
I am reviving an old thread.......
RMCR installed a cam on my C7...wicked mod.
Mark did a flawless job. Was not cheap.
When I added long tubes / B&B Fusion exhaust and dropped a pulley size, I increased about 35 hp, if I remember correctly. Cam and Meth pushed me to 745hp.
Cam install
A lot. As many of you know, you should do other mods associated with a cam install. Modifying the heads (trunions, if I remember), upgrade the cam seals, and a few other things. Then there is the labor associated with an engine which has ~ no gaskets/seals.
to the guy who started this thread, I would consider long tubes as my next mod.
