Green supercharger belt
Anyone had the gates belt put on to reduce noise from belt tensioner.
How does this work is it longer shorter less likely to stretch?
z51vett
Doug
Part was ordered outside GM parts system.
z51vett
Doug
z51vett (07-27-2017)
Mine is on since yesterday quiet as a mouse I can hear exhaust and tires squeal.
Just need to understand does it slip or how does it work, is it shorter tighter???
z51vett
Doug
z51vett
Doug
Received 1,816 Likes
This is what's showing on my repair order K080852HD belt.
z51vett
Doug
Doc # 4841482
This may not be anything but 4062850 maybe procedure to replace.
Part ordered outside GM parts system
z51vett
Doug
Doc # 4841482
The following 2 users liked this post by z51vett:
Bad Dad (07-29-2017),
Perf n Restore (07-29-2017)
My car now is really a fireball now wow I can't take off like I use too fishtales wow where was a this power hiding.
z51vett
Doug
z51vett
Doug
I ordered my green belt, am going to take it with me to my next oil change along with the TSB.
It doesn't seem to be an "issue", aside from noticing a noise which some owners find annoying. It probably wouldn't bother me, since I know what's causing it, and that it doesn't hurt anything.
I have had mine on my car for over 1000 miles. There is a tech bulletin out and if the car is under warranty then GM pays to have it installed. The green belt on my car made the car drive totally normally. Check to see if the car is under warranty and have GM put the belt on the car if you are experiencing 4-8 cylinder wobble which is really annoying. Car drives perfectly now.
Bobert
Bobert
I would do the RPM belt over the green any day. The green is a downgrade in performance from the standard black belt, and a big step down from the RPM belt.
Green are stiff long lasting belts made for diesel/heavy duty applications, not performance applications. They are fine, and will work fine for most people, but the RPM line is superior, stickier, and made for blowers.
