GM should cover all ZO6's engines for 10year 120,000 miles
http://www.roadandtrack.com/new-cars...gine-warranty/
It boost resale of the GT3, not that it needed it, but it shows Porsche's commitment to it's product. GM should do this just because all of the buzz about ZO6's overheating issue, whether it's real or not, it a perception that's out there. This forum is filled with GS owners saying why they passed on a ZO6. Other Corvette owners have no confidence in the best corvette offered to date. As one writer said about GT3's, most ZO6's will not see 120,000 miles in 10 years anyway.
Received 2,379 Likes
It boost resale of the GT3, not that it needed it, but it shows Porsches commitment to is product. GM should do this just because all of the buzz about ZO6's overheating issue, whether it's real or not, it a perception that's out there. This forum is filled with GS owners saying why they passed on a ZO6. Other Corvette owners have no confidence in the best corvette offered to date. As one writer said about GT3's. Most ZO6's will not see 120,000 miles in 10 years anyway.
Bulletproof? Dude head on over to the C6 Z forum and read Katech's report on LS7 AND LS9 valve guide issues---it's the same for both heads--boom! They have started a thread on LS9 dropped valves.
The engine in the 991.1 GT3 I bought for my girlfriend a few years ago went after 2,000 miles. They offered to either buy the car back or replace the engine and give me an allocation on a 911R.
I love my 911R and the GT3 was later swapped for a GT3RS in a color she liked more. Win-win.
I (we!) Think GM overbuilt the LS9!
This was my understanding. The LT4 isn't a LS9!
timmyZ06 (08-13-2017)
Received 1,817 Likes
What evidence do you need? You don't believe that repeated runs to 262* coolant and 320* oil reduce engine life and that they can lead to instant engine failure? Ask any weathered circuit racer if they are comfortable running their engines to those thresholds repeatedly.
My replacement track car has a warning light set by the OEM manufacturer when coolant surpasses 215*. I can hit that in the C7 Z on my way to work on a daily basis just by driving in a lower gear.
I don't know what kind of car your track car is, but coolant temperatures around 215 are quite normal for OEM street cars. One reason is that the higher temperatures can improve emissions and fuel economy.
Would I be concerned about oil temperatures around 320? Sure, but I used to do it quite regularly in my 1000 horsepower boat, and never lost an engine. It severely compromises oil life, so you change it. One of the "nannies" on our Corvettes is an oil life monitor, which takes temperature into account, so that's pretty well covered too.
I can certainly understand your frustration if your Corvette was overheating at the track. However, it does not seem to result in mechanical engine failures, since the car automatically goes into a self-protection mode when the situation gets severe enough.
The oil's fine! ;)
Uhttps://mobiloil.com/en/article/why-...tested-results
Therefore, the engines setup limits are fine.
If your engine turned up weakened a leak down test would reveal it.
I believe there was an east coast guy here that traded in his heavily tracked weakened motored Z. I guess he felt he was culpable!? GM should have calculated in guys like him with this Mass Produced trackable car!
GM and corporations fighting pays dividends!
Warranties!?
Insurance!?
$100k to me gets documentation and my car dropped off! Until we see some guts around here no one will Get It!
Warranties!?
Insurance!?
Received 1,984 Likes
Dude here in Ohio had a Porsche under warranty on the track that let go. Not sure the model but Porsche said not covered on the track and wanted $40K. I was at a race equipment shop and all his Porsche equipment was there for sale and they where saying how they just outfitted the new car he bought.
He now drives a Z.
He now drives a Z.
Chevrolet, another disgrace in their attitude toward customers!
No extended warranty ever on my previous 2007 C6 Z06 - for the rocker arm manufacturing/design bearing failures, and none on the manufacuring/quality control
failures on the cylinder head machining process, the latter resulting in blown engines.
Now we have engineering design failures again, this time with the C7. This time regarding the undersize supercharger and both water and oil cooling systems, and the automatic transmission torque converter failures.
Imagine, not even a recall on C7 A8's to upgrade the transmission fluid with the associated flushes, never mind an upgrade to a larger supercharger to reduce inlet air temperatures with attaendant cooling system upgrades.
Looks like Chevrolet needs to completely clean house in its Engineering Dept, can't do any worse than the current situation. Can't even get Engineering acknowledgment as to the problems, their source, and solutions. Maybe hire some talent from Porsche and other major sports car producers.
If You didn't handle that for our joint celebration how is this helping Now!?
#33
The question is how LONG can an engine hold together from X number of "severe situations" over time.
#34
#35
It doesn't behoove manufacturers to have their products last forever!
Last edited by Steve Garrett; 08-15-2017 at 11:25 AM. Reason: Merge Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your response look like this.
#36
I don't know, isn't that a little like asking how many times other fail-safes can be applied, like reducing timing to prevent detonation? Probably indefinitely.
#37
That's pretty inaccurate. MANY guys that dropped valves had NO track time. There was a survey here sometime ago. Yes there were plenty of track guys who were covered by GM but they were not the majority. I knew several guys and met others at speed shops that dropped valves only one was a track guy.
#38
Leeds.io
St. Jude Donor '14-'15-'16
"911R" is the only thing to come out of this thread.
100k mile warranty on my 10second quarter, low 7min Ring, daily driver, thanks.
Best,
Gene
Best,
Gene
Plstxmd (08-13-2017)
#39
Received 8,928 Likes
We have some track people who have an over heating issue and we have a lot more track people who don't have an over heating issue.
For the people who have an over heating issue once the engine cools down some they can drive the car anywhere they want. A driver of a C6Z with an LS7 engine that drops a valve head at the track gets to have the car flatbedded to a garage for engine replacement. Ever hear any of the owners with over heating issues say they couldn't drive their car home from the track? That is a huge difference.
There is no comparison (not even a weak one) between LT4 over heat issues and GT3 or LS7 engine failures. One is a problem that is resolved on its own within a matter of minutes and the other requires a major and costly ($13K to $17K) intervention to be able to drive the car again.
Bill
#40
The LS7 definitely isn't bullet proof, however, we aren't having issues like that with the LT4. How many LT4 drivers have dropped the guts of their engine all over the track?
Bill
Bill
Please read the quotes in my original post. My bulletproof comments were with repect to another poster bemoning the fact that the C6 ZR was bulletproof and sadly the C7Z isn't.
I love my C7 Z06/07 M7 and have zero complaints.
