Carbotech brake pads steel rotor ZO6
Just ordered our first set of Carbotech brake pads from Adam.
Any install tips would be appreciated. I recall reading a forum members thread on a quick install process, but I couldn't locate it.
Thanks!
Thanks!
Supporting Vendor
St. Jude Donor '11,'13
One more https://www.corvetteforum.com/forums...ch-1521-s.html
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Thanks, Adam!
Here you go same as the GS http://netwelding.com/Ceramic_Pads.pdf
One tip... the clip that retains the pressure on the front pads held in by the pins has an arrow on it to show which way to install it.
I put mine in upside down once before I knew this.
It was still there but shifted.....
2cents
2cents
Adam@Amp'dAutosport.com (09-08-2017)
