991 GT3 RS and C7 Z at mid-Ohio
#41
My experience is that PTM definitely kicks in well before WOT as I've heard the engine fluttering at less than WOT positions. I don't simply mash the gas to WOT either but agree that I could probably get there sooner. The problem is that PTM is not always consistent and it does not guarantee you won't have throttle induced oversteer. Sometimes it works great, others not so much.
I've tried and I'm definitely faster with PTM on that with everything off - I think it's mainly that I have confidence to roll the throttle in more quickly with PTM on. I'm also pretty sure the Mike runs with everything off and usually in Sport mode (not Track mode).
#42
Unless I'm mistaken, doesn't Spring Mtn. cover all things PTM?
#43
Yes it does and I understand the settings very well. However I am trying to learn from the guys that are very fast and have much more experience than me. Poor-sha's comment about the PTM being inconsistent is very interesting to me as I believe I experienced that as well. From a practical standpoint I would like to know the difference sport 1 and 2 as they have seen it on track. After all of this I have realized that I am horribly off topic from the OP.
I will take this elsewhere.
#44
Mid Ohio is a fantastic track! Thanks for the great video's! Back in the mid 1990's I ran there for several years in a 77 March Formula Atlantic!
#45
Originally Posted by Bullet Tooth
The last time out I had a fairly significant oversteer on the last turn in sport 1. That was enough to make me nervous to go to sport 2. Do you typically run in race? I will likely follow the advice above when I am out in a couple of weeks.
Bullet Tooth (09-13-2017)
#46
Bish
rikhek (09-13-2017)
#47
I honestly don't believe this to be true. The Z is about 50/50 weight distribution front to rear and has tremendous balance. Frankly an experienced driver can just about place the car anywhere in a corner and get away with it. A novice as long as they didn't constantly floor the throttle in the Z06 coming out of a corner, should be more consistent and 'safe' than in the GT3 IF THEY'VE NEVER DRIVEN A 911 BEFORE and aren't familiar with a car that has 60% of its weight behind the rear axle.
Bish
Bish
#48
It was a great weekend. I was there too, and did several 1:35 laps in a Grand Sport. Just can't figure out how to post.
FWIW, I prefer "race" mode, but I am still trying to figure out all of the different modes and what effect they have.
#49
I have been trying to use more of the PTM feature. However, it takes a while to get used to doing what you taught yourself not to do. It isn't about slamming on the throttle it is about going wide open which is a difference in how far the throttle is opened Vs how fast it is opened.
I am making more use of it as I get used to the car but have found once it starts operating that adding more throttle usually makes the back end start to step out which causes me to back off a smidgen. Maybe if I did go wide open the back end would only step out a little and I would get a little better speed out of the corner but I don't trust it enough to try and find out how far it will let the rear step out.
I did an autocross on a go kart track last year where I never ran above low gear. I was heavily into PTM coming out of every corner and the car was snapping around the course. I set FTD by close to a second over the normally fast guys that have been running that course for the last 15 years or more. Even while PTM was operating I modulated the throttle when I felt the back end stepping out too much.
Bill
Bill
Rick,
I have the same experience as Bill using ptm, the back end has stepped out some, especially at the left hand corner coming onto the front straight. I'm on the throttle but back out a good amount coming thru there.
I will be back to mid ohio this weekend and again the last weekend of the month. I will get more practice at trusting ptm during this time.
When I'm back at mid oohio the last weekend of this month the gt3 rs in the video will be there as well, except I will have cup2 tires for this event.
I'm assuming most have seen the excellent, comprehensive, technical PTM discussion provided by Corvette lead development engineer Alex Macdonald in response to an "Ask Tadge" question:
https://www.corvetteforum.com/forums...rack-mode.html
I'm not going to repost the entire, lengthy explanation provided by Alex but his comments on PTM/SPORT 2 and PTM/RACE oversteer is pertinent:
SPORT 2: This mode uses the exact same traction control settings as SPORT 1 but turns off ESC completely. This mode is designed as a way to turn off ESC while maintaining a fairly stable TCS calibration. I use it very often. Basically any time where tenths of a second are not critical to my testing or when the tires are getting too hot or wearing out. After 10 to 15 consecutive laps it is likely that your fastest times will be achieved in SPORT 2 rather than RACE.
Slip targets here are the same as SPORT 1. MR is still in track mode and ESC is turned OFF.
RACE: This one is pretty self-explanatory, it’s as fast as we know how to make the car go. This mode is for a well prepared car on relatively new tires with an advanced driver that is completely familiar with the track. The track should be somewhat warm and the tires should be up to temperature.
Slip targets are 100% optimized for forward acceleration, any small variances in the track or tires can result in momentary overslip that will have to be managed by the driver.
A few notes about RACE mode: I approach this mode as a tool to go faster meaning that I think specifically about it when I go to WOT and I try to change or optimize my throttle application point and steering to help the computer do its job. It can do the job better than me but only if I give it good information. A specific example is how I unwind the steering wheel mid corner and as the corner opens up. When learning to drive on track it is good practice to automatically unwind the steering wheel as you apply throttle regardless of the vehicle response (a string tied from throttle toe to steering wheel is the analogy used by some instructors). The problem in RACE PTM is that by doing that you are telling the car you are ready to go straight. It will add power and drive you to a wider line. The best results are found by holding the wheel as steady as you can and pointing the car to corner exit only when it’s time. Obviously you have to be ready to correct for overslip but as you gain trust you will find this is required less often than it feels at first. It is very useful to practice using PTM in the lower modes where you can focus on letting the car go where you point it and not correcting your steering too early.
We find that the calibration settings that achieve the fastest lap times often result in expert drivers feeling like they are being held back slightly on corner exit. Most of the time that extra little bit of slip that an expert driver wants is over the traction peak of the tire and may feel good but is wasting forward acceleration. The restrictive feeling is not there as a safety net, rather, it’s as close as we can operate to the peak capability of the tire in a robust way.
I wonder if you guys (i.e., Bill and Slimm) need to grow a set and correct the step-out/oversteer with steering input instead of lifting? For the record, a little bit of humor was intended by this remark. As a racer, the last thing I want to do is lift if there is any chance of correcting with other inputs. I experience these step-out/oversteer situations on a regular basis when running in PTM mode but have learned to override my brain and not lift but to correct with steering input. It takes a leap of faith and I still occasionally can't stop my foot from lifting slightly but the more I track the car the less I lift.
Almost like going up the esses at the Glen in a race car. My mind is screaming lift/feather a bit but I know the aero down force, tires, suspension, etc. will allow me to keep it to the floor all the way to the bus stop. I've learned to clench my *** and keep it pegged...
I stress it's taken me time to learn to trust PTM and even now when I go watch my PDR video I catch myself not committing to full throttle application at the apex and/or lifting due to a bit of oversteer tracking out. I see this even though I swear to all my friends I go to the floor and don't lift, however, the curse of video/data is that it doesn't lie.
On a side note I've been chastised at races where Mike Levitas or Randy Pobst are helping me with coaching and data analysis. They'll come over and tell me I'm braking too early for a corner or lifting/feathering through a section and I tell them they're full of ****, they're wrong and I'm all in. They then say, "OK, pull up your video/data and let's have a look".
They've shown me to be a liar and lacking ***** more times than I care to admit. Damn video/data sucks as it doesn't lie like I do ...
Rick
The following 3 users liked this post by rikhek:
#50
I posted the videos in my original post on YouTube and linked them here. You could try doing that.
I will see you again this weekend but I don't plan to put the cup2 tires on until Sunday. Hopefully this weekend will be just as fun.
#51
I'm glad this came up. I always run in Sport 1 on the track because I want the active handling safety. I have seen the explanations about the differences between Sport 1 and Sport 2, but I haven't had the nuts to run in Sport 2 on the track. Have you and which have you found to be quickest?
I can't get the video out of my head from a few years ago where one of the posters had an oversteer out of turn 20 at COTA and backed his car into the pit wall in a very unusual setting. He was running in Sport 2 and to be honest I haven't ventured over that far yet.
Sport 2 with PTM provides a safety factor even though TC and Active Handling are disabled as is also discussed above. When I do run Sport 1 I don't find the AH hurting my times or intervening to an extent that's annoying. It's not a bad mode to run, however, I guarantee it's not too difficult to spin in Sport 1. I speak from experience...
Rick
#52
FYI, Mike does not track his car in SPORT with everything turned off. That's how he runs his car on the street as he loves sliding it around. On track he "always" runs in a PTM mode. He's using PTM/RACE nearly all the time.
#54
Cruise-In II Veteran
Cruise-In III Veteran
Does the PTM still operate in race mode???
I have a Z07 with the MSRC, when I set the track mode in the sub menu to 'race" does PTM still operate? Would hate to drop the throttle to the floor at apex if it wasn't going to kick in.... thanks
Bill/Slimm,
Bish has hit the nail on the head. With PTM it's all or nothing. If you're not going hard to the floor at apex the car doesn't engage PTM. The *** end is stepping out on you guys due to driver "modulated" power delivery. Basically, you're on your own except for active handling provided you're in Sport 1 or less and you don't go rather quickly to full throttle.
Again, it truly is a leap of faith and takes a big set of cajones the first couple times.
Rick
Rick
#55
Yes. However, to get comfortable with something so completely foreign to what our brain tells us I'd suggest starting in Sport 1, then Sport 2 and then going to race. As mentioned above, some oversteer "might" occur in RACE to which you need to provide a bit of steering input to correct. If it occurs, don't lift, just steer.
#56
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Great thread! My experience has been there are specific tracks for specific settings based on driver experience. For instance I ran a shorter technical track this summer in Sport 1 most of the day and switched to sprt 2. Yes the car had better lap times but it was some work and hardly worth it! Now Watkins Glen and the infamous Esses I will not switch to 2. Climbing the hill even in Spt 1 the back gets loose with a steel wall only 100 feet away! Pucker factor and my brain have a fight and its a toss up who wins per lap. My suggestion to many at the track is keep it safe first speed comes with seat time.
Hey Rick I turned a couple 2.03 lap times this summer at WG on worn out cups, very happy and surprised as I had a rider! I like to send you my videos to critique if you have time. PM me your email. Looking for 2.0 or sub on slicks next summer.
#59
Received 2,050 Likes
Enjoyed the videos OP.
Correct me if I'm wrong, but the rear brakes will wear faster with PTM intervention (less in sport 2 than 1 depending on drivers input of course) and extra torque is managed by throttle blade, fuel and timing only in race? At some point all the electronics will take the challenge out of it and it'll literally just be a roller coaster ride it seems.
#60
Pre z06, racerdj and anyone I may have missed thanks for the comments on the video.
Koan, we've met several times. I have the black c7 z06 and my brother has the white c6 z06. I previously had the orange (dsom) c7 z51.
