Dash Command is a great value for the money!
I've been looking around for an affordable device that can monitor the my IAT and etc. I didn't want to a lot of money on a HP tuner software or dash logic unit (I didn't like how you can only view your information on TOURING mode only with the dashlogic).
I came across an app called Dash Command for $10 on the Apple Store. Purchased that app and a OBD2 dongle for $20. Total spent was $30 and it works like a charm.
$20 OBD2 dongle
$20 OBD2 dongle
Kouasupra (09-23-2017)
check your messages already, will ya!!
Looks dope!! How did you mount the iPad?
Great find!
Does this record any data or just monitor?
Also, are you using the same mount for your phone?
stangin4lyfe (09-24-2017)
Keep us posted on what it can and can't do please.
It appears that timing is not working and power only goes up to 500, but the other features look very interesting, especially for the price!
Kouasupra (09-24-2017)
Have you figured out any of the custom PID's for the LT4?
It is a great tool at a very low price. I used it to datalog my C6 timing, O2 sensors, fuel trim, rpm, vehicle speed when I was troubleshooting a hanging idle problem.
Kouasupra (09-25-2017)
$20 OBD2 dongle
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$20 OBD2 dongle
Then open the Dash Command APP and it should automatically try to connect. You'll then need to check your APP settings and set up your vehicle, etc..
Go into your iPhone's Settings tab...then WiFi... under Choose A Network you should see the OBD-II listed as an available network. Select it and the phone will connect to the OBD-II and show the little WiFi graphic in top left corner of your phone screen.
