Personal Best Lap Time at VIR this Last Weekend
#81
Received 8,928 Likes
Not sure what difference it makes but the fuel rail pressure sensor voltage on sensor 1 is 3.21 and sensor 2 is 1.86. I'm sure you've already seen it but that's the first thing that really caught my eye. That and the fact that all of the misfires occur after 5,000 rpm. Your cat temps look high but that might be normal at that speed and rpm. Looks like all the misfires were in a narrow range of mileage so they all probably occurred at VIR.
Sorry I'm not much help.
Bill
#82
What is the normal operating parameter for the fuel pressure sensor voltage? Should there have been a code thrown? Related to your observation the dealer mechanic says the fuel level sensor readings are all over the place which he thinks indicates the fuel is sloshing around in the tanks. He thinks that is causing the fuel to be aerated and when it gets pumped up to the DI pump the aeration results in a lean fuel mixture being injected the cylinders. The GM engineers disagree with that but don't have a rationale for why the fuel level sensors have such readings.
Bill
Bill
#83
I'm not sure about the parameters but I wouldn't have thought there would have been that much difference. It could be load related and your mechanic may be correct the fuel could become aerated. If the fuel was sloshing away from the pump I guess that should happen. Did this happen on the straight or coming out of a curve. Either could cause fuel to slosh. Does it happen with a full tank of fuel or after you've run a couple of sessions and the fuel is low? If you could narrow down all the variables that you are aware of it will probably help the tech narrow it down. I'm not a mechanic so you can take my observations with a grain of salt but it sounds like you have a decent mechanic working on it. The more you can isolate the problem the more likely you will be able to fix it.
I am pretty sure the misfires occur as I accelerate up the straight. From what can be seen in the pdf I attached previously the misfires occur at just over 5K rpm at 100% engine load with the speeds in the low 100s which means the car is pulling hard in third gear. There may be something else happening at a lower level as it seems the car is loggy even in 4th gear above 5K but there is no misfire data recorded. They also seem to be in cylinder #8 which along with #7 in the LT4 are the two cylinders that run hot. By hot I mean higher combustion temperatures than the other 6 cylinders.
Bill
#84
The history files show the fuel tank was 89% full on one occasion. That means the left side tank was full and the right side was probably about 75% full. It is far above the fuel pump inlet. The mechanic is thinking the sloshing is getting air mixed into the gas in the tank not at the pump. That would mean very small air bubbles in the gas like you would see if you put water into a blender and turned the blender on.
Bill
Bill
#85
I figured from the printout that you had to be on the straight but I was just making sure you weren't in the esses which could definitely cause fuel to slosh back and forth. I wonder if the fuel is boiling in the lines? It probably shouldn't be but that would probably have similar results to air ingestion and may be more likely as we push the engine harder. I had the same problem with a 70 big block car I ran and we finally put in a larger fuel pump and a bypass line to circulate fuel back to the tank. Problem solved. These engines have a lot more fuel pressure and it's probably less likely to be that I just thought I'd throw it out there.
#86
[B]
YEP, badhabit you get it!! SOOOO many have chased this issue and I just don't understand why Bill you ignore this known problem?? I know you don't have an A8. With my 2016 A8 Z07 at VIR second and third lap starts with seat by the pants power loss, then check engine light or misfire codes and even random codes. 4th lap complete limp mode, some times no engine light at all just full limp mode . I have had the Z in two different GM dealers and the best TECH can't figure it out. Badhabit is right on the money GM knows, why do you think larger bricks did not fix the problem for forum members that know how to track their 2017 models?? Can you say ZR1 and new Camaro with 11 coolers
Maybe it is the cats breaking down. Perhaps the coils or plugs aren't up to lots of hours at high RPM use and start to fail. Perhaps there is oil build-up that is affecting the back cylinders. I don't know but I'm glad Bill is ******* this issue as I suspect more and more folks will start having it if they track their car a lot. I was just ahead of the curve a bit on that.
#87
I don't think this is Bill's issue and it wasn't my issue. First, Bill's car (and mine) never had issues like this when new when the ambient temps were much higher. It seems like after these cars have a lot of track time on them it starts becoming an issue. I posted this in the other thread but in both of my cases the issue was a bad catalytic converter. I don't know if that was my issue the third time as I just sold the car.
#88
The problem is intermittent. Sometimes it starts affecting performance and it will last for a day. The first time I experienced it was last year at the Glen. Starting with the third session of the day I was getting very poor top speeds on the back and front straights. I had a lot of tire vibration that day so thought that all of the vibration could have caused timing to be pulled. The car performed very closely to what my 97 C5 performed and I ran another 5 20 minute sessions with the car performing like that. It never went into limp home mode and never through a code. You can't say the car is in limp home mode if it is capable of pulling 137 mph at the end of the back straight when it should be pulling 150+.
When I got the car home the dealer mechanic couldn't find anything wrong with it. Then I went to VIR for another event and had no issues at all. This year I started getting sessions at VIR where the performance was lower than expected. A lot of times riders have no idea anything is happening unless I tell them. The most obvious occurrence was at the Glen this year. I was there for a 3 day event and on the afternoon of the last day the performance dropped off. During the last session I took a friend for a ride. The first three laps the car ran fine and then it started falling off and I mentioned that it wasn't putting down all the power it could. Then on the 7th lap we were going uphill through the Esses with a wide open throttle and I suddenly felt the car surge as full power came back and the car ran fine the rest of the session which added up to another 7 laps.
This isn't an over heat situation like the A8s have. The coolant and oil temps are no where near overheating levels. If it was an overheating situation it wouldn't go away when the engine was at its hottest operating temp.
There are only a few cars that seem to have the same issue. When I was the NCM VIR event this year there were 3 other owners reporting similar results. We ran out of time or the GM engineers that were there would have been able to put a monitor on the car to see what was happening.
The one thing I do know this year is it happens more often and it sometimes just disappears in the middle of a session.
So what kind of things would cause misfire symptoms that come and go. Over heating more than likely wouldn't, a failing coil might, an interruption in intercooler cooling might, a cracked spark plug might as well as a spark plug wire that is starting to break down. On the fuel side maybe the system runs lean every now and then.
Having seen the emails the GM Engineer has shared and talking to the mechanic at the dealership the engineers believe the issue is in the intercooler circuit. The first thing the mechanic did when he got the car in his bay was take the cap off the intercooler to make sure it was filled to the point he filled it before I went to the track. It was still filled to that level.
Bill
Bill
#89
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Bill its disappointing the issue cannot be found. We have identical cars although I have the 100 octane GM tune as of this year. I've never felt such a power loss this passed season. Although a few yeas ago sometimes on 93 octane it would act a bit sluggishness but very minor. One would think that if my car has no issues then maybe it could have to do with mapping. I will need to pay attention next year more. I bet this is a non issue for drivers that don't push their car 9 to 10\10ths consistently.
Having the car come alive while going up the esses at WGI at WOT would make my heart skip a beat!
#90
Bill
Bill
#91
Originally Posted by badhabit_wb
I think it's great he's trying to chase it down. His converter temps seemed high but I'm not sure what they should be at that load and rpm. Do they have heat shields on them? Poor-sha did yours have heat shields? That could cause the converters to overheat. I guess if the converters could be removed and a converter delete pipe used in it's place that would remove one variable.
#92
I guess the intercooler circuit is looking more and more likely...I hope it's that simple honestly. Granitelli makes tank that holds a gallon and three quarters more fluid that might add enough extra capacity to at least solve that part of the equation.
#93
I had the front clip off my car last weekend installing the secondary radiator. I looked at my intercooler tank and there was a small bubble that looked like what I'd seen as normal. I'm wondering now if I should have gotten that last bubble out. It could be that the tank is too small and there's not enough cooling capacity there unless everything is optimal. If you have a problem there it would explain the off and on nature of your problem better than most of the other things that have been mentioned.
When I took the car back to the dealer on Friday the first thing the mechanic did was remove the cap and check to make sure the charge cooler coolant level was still at the level he filled it to.
Bill
#94
I had the same experience you stated above, never had issues like this when new (1st year) and the ambient temps were much higher toward the end of season. Then starting second season in May, BAM first track day at VIR limp mode and it went down hill from that point. I through the same codes as Bill, the first Tech bled the intercooler cooling system with no luck.
In my opinion most of us had no issues when new but after the intercooler starts loosing just 10% efficiency by daily driving IE bugs dirt and track use, the intercooler cant keep up to task. This can elude to all kinds of problems with supercharged engines like Cats, plugs on and on.
I hope Bills problem is as simple as wires or plugs.
Poor-sha (11-20-2017)
#95
Bill
Bill
BTW my A8 has never overheated, engine oil and coolant temps are high but not extreme. I will be installing LG additional intercoolers hopefully in the next couple of months, I'm pretty sure that will be the fix.
