Z06 M7 Clutch type?
Received 2,053 Likes
Twin
No
It's the same across the board like c6 base, GS and Z06. Will be interesting to see if it's in the c7zr1 too.
No
Clutch?
I have a 2005 C6 with wide body kit, Vortech supercharger, cam, AT headers, stainless x-pipe, Billy Boat exhaust for 615 HP at the wheels. My much said to put on a Z06 clutch instead of what I had. Are you telling me the bass Grand Sport and ZO6 clutches are all the same for my 2005?
The Consigliere
Received 5,444 Likes
^^^ Actually only the ZR1 in the C6 gen had a twin disc. Rest were singles.
The Consigliere
Might be easier/less $$ for him to just put an aftermarket twin disc in.
Former Vendor
Twin disk is stock in C7 Base and Z06. If anyone needs an upgrade i have a Mcleod RXT clutch and flywheel package on the shelf in stock i can give someone a great deal on. Just parts or with install too.
According to GM parts Expert Gene Culley, who is very knowledgeable, C7 Z06's come with a single disc clutch. However, the Z06 clutch disc and pressure plate has a different part number than the LT1 (stingray /Gand Sport) clutch. I would assume higher clamping rate.
Thanks PRE-Z06 for additional info as stated in next post.
Plate load is the same from experience of testing them on the bench when I worked for Monster clutches, they offer other discs with higher coefficient of frictions to allow more holding power in other models that use the pressure plate for OE pedal though a lighter billet flywheel instead of the heavy OE dual mass unit.
Perf n Restore (10-19-2017)
