WEAPON-X installs the first 2.9L Whipple on a C7 Z06
#141
long story short... the stock c7 blowers have cooling bricks that have "fins" the coolant flows through, on the windshield side of the blower. If one wanted to attach a small port to be able to bleed the air out of the top of the cooling bricks, it would be a soldering extravaganza/nightmare. A person would have to weld on many tiny ports, i think like 12 or more, and then build a collector where each line collects... nightmare...
Meanwhile, the bricks of the whipple 2.9, their cooling fins dont extend all the way to the windshield side of the blower, instead, there is the "collector" where the passages/fins all dump and re-unite. This means one can use a single normal size port, to tap into the cooling brick at that spot, and be able to bleed the system.
One would want to mount a air tight tank that is equal level to the port holes, off the side of the blower. I have figured out how the coolant/air hard line(s) would exit the blower. This small tank outside the blower can then be bled to see how much air collects in any given amount of time.
I think the results will surprise people. This also keeps air from collecting inside the bricks, as it now has a place to escape to.
once this is done, and people see how much air is collected, the whipple 2.9 will have a huge advantage over the stock bower, for that benefit alone... as the 2.9 bricks can be tapped into with 1 port on each brick, and the stock lt4 bricks are going to need many many ports soldered to each one of the fins, and it would be a nightmare.
One can also then run a thermostat from those ports, and know when the stock GM water pump for this system shuts off for 3 min at a time.
Knowing when the pump is off, keeps a person from melting the bricks, as I have leaned from other forum members, actually occurs, and i bet melting of the bricks occurs even easier on the 2.9 than the lt4 blower. Power equals heat.
It will also make bleeding the system a dream, and by keeping air out of the rest of the system is how one keeps the water/coolant pump from experiencing cavitation.
Below are videos of the current nightmare process to bleed the system...
https://www.youtube.com/watch?v=u9lA_Lhovx8
https://www.youtube.com/watch?v=ff5dCX1TEAY
#142
The air capture res I am speaking of, needs to ensure the bricks NEVER have caught air, standing in the top of the bricks.
#143
That is my plan, buy this blower eventually with power turned down so that I can keep up on fueling until i feel i understand the system well enough and the tune well enough to start moving up in fueling capacity and thus power.
Spinning it slower makes MUCH LESS heat than our current setups being over-spun.
This means the timing can be advanced in the engine to make more power as the intake charge will be cooler.
All that being the case... you still have the cut of the window cowl to deal with.
Here are my thoughts...
Its my opinion that the last 2 cylinders by the window, being the first to overheat, on many cars on this forum, which causes knock/predetonation, and thus pulls timing and thus pulls power from the engine....
my opinion of why these last 2 cylinders are the first to get knock... is due to the location and architecture of the bricks. Chevy and everyone else has to keep them as far forward as possible.
Whipples system was not designed around the vette, therefore the bricks locations are not compromised. They WILL keep the back 2 cylinders more cool than other blowers, apples to apples, and thus a person will run safer with more power.
Thats why the windsheild cowl needs to be cut. Tradeoffs, but if I am keeping the car for a while, this is one i would be happy to make.
#144
If you would take a factory blower apart and look at it, you will find that these brass fitings are not higher than the coolant bricks, and you would also find that air gets trapped in the coolant bricks as there is a low point in the system between the bricks and the brass fittings, and you would also find, that these fittings are not a reservoir to catch air at its highest point since they are just bleed fittings on a high flow speed line, and you will find if you DID try to put an air res attached to either of the factory ports, it would likely not be in a position to capture or grab air as fluid and air bubbles flowing through that line is flowing very fast velocity, where as when the bubbles go through the bricks, the channels they pass through are thin, which kind of catches the bubbles like a vice from 2 sides. Thus, why the air settles in the bricks, not to mention, the bricks are the highest point in the system.
Oil debris clogging and
coated intercooler from the factory PVC hurt more than the non issue your reaching for.
I'm going to all 2300 Here is the 2300 inside Looks to have really nice great cooling. I put one on and it runs cooler temps and cooler ITA"S . I think your making a mountain out of a mole hill!
Mikec7z (07-21-2018)
#145
i saw your thread of the oil a while back. That sucks huh. I check my blower from time to time, all is well.
Anyway that is a good photo of the cooling bricks in the 2300... it looks as tho they DO have the collector at each end of the cooling brick, so one could port the windshield side of the brick, and have a hard line coming out of the blower.
I had a couple good plans with the FLAT lt4 stock blower lid on how to have the bleed lines exit the blower lid and seal it up air tight. The 2300 and whipple, i would have to study, the curved tilted lids make my lt4 blower line escape idea through the lid, not so viable.
#146
I had a couple good plans with the FLAT lt4 stock blower lid on how to have the bleed lines exit the blower lid and seal it up air tight. The 2300 and whipple, i would have to study, the curved titled lids make my lt4 blower line escape idea through the lid, not so viable.
Keeps that oil debris and stuff out. Not sure why your worried about drilling the intercoolers? When it is really a non issue there is not a bunch of air in there hurting any cooling the liquid displaces the air and it is gone. Let them design the intercooler's they work great as they are. So much GM had them flat then tipped them for 2017 in the wrong direction to bleed air how did they do that?? They did that to get a cooler air charge to 7-8 which could be an issue on the 201-2016.
#147
You wouldhave to take the blower off and flip it over to see the issue. I'm adding the Mighty Mouse Solutions wild Catch can to both my builds
Keeps that stuff out. Not sure why your worried about drilling the intercoolers? When it is really a non issue there is not a bunch of air in there hurting any cooling the liquid displaces the air and it is gone. Let them design the intercooler's they work great as they are. So much GM had them flat then tipped them for 2017 in the wrong direction to bleed air how did they do that?? They did that to get a cooler air charge to 7-8 which could be an issue on the 201-2016.
i dont know if it happened to his car, or a friend of his' car... but someone's cooling bricks got melted he said, and they have to buy new ones. And they aren't cheap.
I asked how... and I already knew the answer... he went on to explain that the stock water pump for the blower's cooling system... when it shuts off for 3 min at a time... due to air around the pump, causing cavitation...
during that 3 min window, the blowers get scorching hot, and it literally can MELT the solder around the cooling bricks that they are constructed with, and they begin to fail and probably leak coolant and throw solder into the valves and chamber. Or maybe, they just burst as the fluid boils somehow. Either way, Fantastic huh?! lol...
Anyway... the root devil of all of this is AIR near the pump causing the cavitation. The only 2 spots the air slows down and separates well and collects, are in the stock/aftermarket res tanks... and also in the cooling bricks.
So, we need to get it out of the cooling bricks...
To keep air out of the system, the best possible way is to capture it at the system's highest point. So that's when the bricks become the target zone.
Then, as I explained yesterday... you can kill 4 birds with 1 stone...
1. you capture the air to keep it away from the water pump and eliminate 3 min off's from cavitation
2. you now have a perfect place to bleed the system from when you add more fluid to the stock fill port, and can push all the air out of the bricks via the new bleeder setup.
3. you now have a place to install a thermostat that tells you the literal temperature of the coolant inside your bricks. I would put it outside of the blower, but still, so it will be a 20 degrees or whatever lower maybe than inside, but the purpose is not to get an accurate reading, but more of a relativity reading, to know when the system is super hot, vs normal temp... and one could wire an alarm up to that thermostat/kit. Then you know your pump is doings its 3 min off thing, or its failed completely.
4. the cooling bricks operate optimally as they are filled with fluid all the way to their tops, instead of air.. so they do their job better at all times, even when the pump is on.
Some of us drive our cars really hard. These things happen to us, and not other people. So we go the extra mile.
#148
Ironically, Drew, confirmed my suspicions of potential worse case scenario, just last night as a matter of fact...
Anyway... the root devil of all of this is AIR near the pump causing the cavitation. The only 2 spots the air slows down and separates well and collects, are in the stock and aftermarket res tanks... and also in the cooling bricks.
People like LG who race the car add the cheek coolers. Then is other members who race with the 1.7 and the 2300 on the Z06. Doubt your running harder than any of those. First I have heard of this issue and doesn't Drew have the 2.9? Then your not sure if it was his car. I'm out on this subject total non issue and not worth the thought about air bubbles in the intercooler.
Good luck with that!
Mikec7z (07-22-2018)
#151
https://www.corvetteforum.com/forums...ed-points.html
#152
https://www.corvetteforum.com/forums...and-sport.html
https://www.autoblog.com/2018/07/23/...021&yptr=yahoo
How did they get it under the windshield cowl?
#153
Mikec7z (07-29-2018)
#154
Received 2,379 Likes
from what I understand the yenko pic is just a mock-up. is there a video showing it running with it under the cowl or are we looking at vaporware?
#155
for those that dont realize it yet, the Yenko WILL be a collector car that will appreciate in value. Old money guys will drive this price up quick.
#156
St. Jude Donor '14
As for the fitment, that cowl is not OEM, my guess is they spaced the cradle down a little like we do and then did an aftermarket cowl; however, you can only lower it so much and the rest of that room would get taken up by the hood gasket since the hood is OEM and you're relying on the hood to absorb the stress. Look for a video of the hood opening and if it pops a foot off the cowl when pulling the lever, you'll have your answer. Either way cool car and love to see the innovation!
#157
i agree with what you are saying about it being out of the public eye for a long time...
however, the key here is that a person can order it from a GM dealership and GM endorses the order.
That is a HUGE deal on collect-ability, because now it is still a "production car" that is very rare. Don't ask me why it is a big deal down the road, but it always is.
and if they make less than 25, even better. Usually the most collectable cars are the overlooked, low production cars. Example, the HERTZ corvettes back in the day... they are worth a lot of money these days. They weren't faster, they were just rare. Then GM brought that back, and made a big deal out of it on the c6 or c5, i forget, but once a huge deal is made, its usually not going to be collectable, as people pay too much to begin with.
I am curious to see what front fascia they end up using. The stock nose is not going to cut it for cooling.
I would bet money that Hendrick has already spoken for #01 of 25, and will pay well for it, so i am pretty confident we will see these come to fruition. Jay leno might buy one... this is a car they will make phonecalls to a bunch of old guys with money, and personally invite them to be a part of... and with only 25 units made, they will buy them up. A couple will end up in the middle east, a couple in germany, etc.
#158
#159
St. Jude Donor '14
Aluminum does not melt until over 1220* F.
Water boils at 220*.
Dexcool 50:50 boils at 250*.
Distilled water boils at 212*.
The ABS Tmap sensor would melt at 221*.
If the system had an expansion tank, most caps reliever around 15psi.
Rubber gaskets around the intercooler bricks would melt over 350*.
The fatigue temperature of every other component in the system would be reached before the aluminum bricks would melt.
Removing air from the supercharger system is not difficult. Vacuum filling and pump cycling is all it takes. Think about how many LS and LT superchargers are out there making big power without issue, but this logic is being based around a couple of outliers. We rarely see temps over 130* on 20+ PSI Whipples with our heat exchangers and/or tank kits.
Answer is simply installer error which happens to the best of us, and while I agree these systems could benefit from some simple bleed ports, they're not flawed to worry current owners.
The following 4 users liked this post by Ben@WeaponX:
