GM cold air intake for ZO6
#41
Former Vendor
Exactly what I was thinking. Not sure how much advantage it can give without a proper tune or calibration update unless it's just a hype. I stayed away from cold air intakes because they require a tune to get the most out of them but with a tune you can kiss warranty goodbye.
#44
However, I could be wrong. I'm still wondering how GM was able to rewrite the ECU calibration for us with 2017 cars that were throwing a P0106 code when driving at speed. They did this in a very short time frame when you consider all the parties involved just within GM.
Rick
#45
Even with Scott Pruitt at the helm I believe the EPA might take issue with retuning the car. I think it would be economically impossible to do with all the red tape involved in altering an already "tested and approved" engine management system which could effect power and subsequently emissions.
Rick
Rick
#46
Excuse me if I'm wrong but I didn't see where it said Z06. It might be for C7.
The filter looks the same only a different housing. Better power per dollar with a Halltech. This might be more money than a Halltech too.
#48
A more efficiently breathing motor does produce more power... but nothing ridiculous.
The ridiculous gains by aftermarket suppliers come from a larger MAF housing that tricks the MAF sensor and pushes more air than the sensor is reading, leaning out the A/F ratio and making more power.
One voids the warranty, one doesn't (despite claims otherwise).
#49
Originally Posted by Jpjr2016
Cold air intake improves airflow, just as straight pipe exhaust improves airflow over mufflers.
#50
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
#51
NCM Lifetime Member
#53
NCM Lifetime Member
Different plumbing on the Stingray. This one is designed for the Z06 SC.
Gonzo (06-21-2019)
#55
NCM Lifetime Member
Considering I just went back to stock on my Z, I don't think I'll run out and buy this.
#56
You got to admit the above CAI pic with the special lighting/photo shop makes that thing look good!
GM should of done that from the beginning; looks like they were thinking of the AFE CAI when they created it which would of let GM advertise the ease of checking your air filter by just lifting the hood. GM 'maybe' could of made 665 HP (?) with that CAI on the car, that would of sold some more Z's.
https://www.corvetteforum.com/forums...or-zo6-cai.jpg
#57
NCM Lifetime Member
Going to be interesting to see a before and after synonymous on an otherwise stock Z06.
#58
I saw the new intake kit as well, but no pricing was listed.
#59
Originally Posted by Kevin Parent
Picture.
#60
Received 1,817 Likes
Maybe it was already needed and designed for the ZR-1, so they figured they might as well sell it for the Z06 as well.
Gonzo (01-28-2018)
