Installing ZR1 wing on a C7Z
#41
It makes sense but it’s probably a very small small improvement. I’d have a lot more confidence if I didn’t get oversteer entering 50-60mph corners at Sebring. The car is super planted in the high speed sweepers but loves to swing the rear out in the slower corners.
#42
Frankly, the current stage 3 wicker provides a pretty decent amount of downforce - just look and the impact to the rear suspension with speed. They showed the data in the original lightning lap issue. It just does it with more drag than a wing.
Someone should tee up an Ask Tadge to describe the aero properties of the C7 ZR1 relative to the C7 Z06. By the time it gets picked the car will be announced.
And there is the adjustability factor.
I'm in with rikhek if the installation is feasible for a reasonable price.
#43
Received 1,817 Likes
#44
The issue is that this barndoor flap exacts a huge drag toll. A wing generates the same DF at 1/4 to 1/6 the drag penalty. There was an enormous amount of research done on this in the 70s.
TTRotary (11-10-2017)
#45
Data and charts for this wing?
Dane,
DO you have any data on how this wing? Interested in how it interacts with the C7 body aerodynamics. Looking for information such as the amount of downforce/drag at various angles of attack.
TIA,
Bill
TIA,
Bill
#46
I had it on my 2015 Z(red mirrors, the other one is my 2017)its not bad at all. Good downforce, and adjustable angle. You need to add/increase the front splitter on the car to equalize, if you would like to know more just PM me
Hemi Dave (12-04-2017)
#47
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
This seems potentially fraught with folly. The reason I say that is: aero balance. If that wing does, indeed produce the epic amounts of downforce we expect it to, the front end of the ZR1 (including its extra 140lbs) will be just as important: balance at speed. Otherwise you're probably going to run into a very light steering wheel and that oh-so-unsettling push on track.
Approach this one with care. Don't approach it like the aftermarket, as they generally don't have the aero knowledge nor testing facilities to verify and validate.
Well said. jvp, do you know if the adjustable will will need to be manually adjusted or will it be electronic?
#48
The only way/reason it would ever be electronic is if it was part of an active aero system.
Rick
#49
Im sure there will be many options soon. I’ll be making the full front, or at least the front bumper.
As far as the wing, been long time planned and I finally got around to doing the chassis mount. Planing on 1/2 the price of the current very expensive wing mentioned above.
not this
Too angular and protruding.
the yellow car? A design like that is what any MCE should look like imo. I would install that on my car. I don't like the actual ZR1 bumper corners.
the wing is a great show piece for the 99% of future ZR owners lol
#50
If you male the front bumper look like this not tjat hideous hack job GM did, you'll be Rich (er) lol
not this
not this
#51
Premium Supporting Vendor
It is the GT2 wing. I don't have any numbers on the wing for the C7. I'll check with Lou.
Kaged (11-14-2017)
#54
What will the 2019 ZO6 look like ??
Ok, so on 11/20 the 2019 order guide will be released. Will the 19 Z change or adopt anything from the ZR1 ???? Or will it be exactly the same as the 18 Z ???
Guesses welcome I'd like to see some cooling improvements, I.e. the ZR1s front grill. I'd also like to be able to get the small ZR1 wing.
Any chance GM will incorporate anything new on the ZO6?
#55
Received 3,803 Likes
"Ask Tadge" Producer
#57
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
It would concern me to screw with the fantastic balance of the Z07 as it is. With that said I'll wait till Rick or Sean adds a wing and splitter and copy them....
It appears not to be very hard to mock up a set of braces from the bumper reinforcement up to the wing brackets on the C7. I bet many companies will be selling wing kits more then ever now with the ZR1 released. Hope they complete the package with a properly tested splitter.
2018 will be interesting to say the least!
#58
Not a great pic but the only one I could find right now...
GSpeed rear wing mounts with the Dual Element wing designed by Simon McBeath coupled with the extreme front splitter from Gspeed that I helped to develop with them. Probably going to look at adding some diffuser sections to the front splitter and work on some different side skirts.
The beauty of the GSpeed wing mounts is that it mounts/dismounts in under 5 minutes and does not cut up the rear cover. You only have to drill holes in the lower cover which is easily replaceable, inexpensive and already painted carbon flash. No color matching necessary.
Rick, I met you the other day at Hallett. If you want to see/drive the wing/splitter combo just let me know.
#59
found some other pics:
see how it mounts
front splitter
see how it mounts
front splitter
