Do I need new pads ???? - CorvetteForum - Chevrolet Corvette Forum Discussion
C7 Z06 Discussion
General Z06 Corvette Discussion, LT4 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Old 11-13-2017, 07:30 PM   #1
TopSpeedNeed
CF Senior Member
Support Corvetteforum!
TopSpeedNeed's Avatar
Default Do I need new pads ????
Was at VIR Labor day weekend, going through tech, was told I need new front pads. These pads are a little pricey, but if I need them, I need them, but these seem to be only about half worn. With nothing to compare them too, can somebody enlighten me if I need new pads, here is pics of both front.
TopSpeedNeed is offline   Reply With Quote
Old 11-13-2017, 08:54 PM   #2
Edwardz
CF Senior Member
Quote:
Just for comparison, this is my 2016 with 45000 miles. (All street) Where did you get the indexing pin on the lug?
Edwardz is offline   Reply With Quote
Old 11-13-2017, 11:33 PM   #3
madrob2020
CF Senior Member
madrob2020's Avatar
Quote:
45K, Wow! Alright-A driver not a poser.
madrob2020 is offline   Reply With Quote
Old 11-14-2017, 12:10 AM   #4
charles7970
CF Senior Member
Quote:
I'm wondering the same thing since i as well have the CCB
charles7970 is offline   Reply With Quote
Old 11-14-2017, 12:13 AM   #5
Torch-Red-Z06
CF Senior Member
Torch-Red-Z06's Avatar
You can buy them here. https://www.reverselogic.us/phone/index.html
Torch-Red-Z06 is online now   Reply With Quote
Old 11-14-2017, 07:52 AM   #6
TopSpeedNeed
CF Senior Member
Just as a reference, I have just a little under 6K on mine, but my car is not a daily driver. I do about 5 or 6 HPDE's a year.
Old 11-14-2017, 10:59 AM   #7
billsc1
CF Senior Member
billsc1's Avatar
Good rule of thumb... when the friction material on the pad is equal to or less than the thickness of the metal backing plate it's time to replace.
billsc1 is offline   Reply With Quote
Old 11-14-2017, 11:09 AM   #8
madrob2020
CF Senior Member
madrob2020's Avatar
Full disclosure-not a tracker-but have seen post of folks who do stating the pads/rotors heat up more rapidly with less pad & fading "may" become an issue. Track safety guys probably have no stock in brake pads, so they are just trying to keep something bad from happening to you & your car in the moment of hard braking (lots of that on track) to experience fade when expecting normal slowing or worse failure.
Old 11-14-2017, 12:02 PM   #9
spearfish25
CF Senior Member
Your pads look fine for now. You’re gettin close.
spearfish25 is offline   Reply With Quote
Old 11-14-2017, 12:52 PM   #10
BEZ06
CF Senior Member
BEZ06's Avatar
Hey Tony
I agree with Alex - they look good for at least 1 track day, and expect you'd get 2 full days out of them at VIR.
Are you gonna be down to Daytona Dec 1-3 for the annual Audi HPDE? Hope to see you there. After VIR you'll definitely need a new set of pads for Daytona!!
Bob
BEZ06 is online now   Reply With Quote
The Following User Says Thank You to BEZ06 For This Useful Post:
TopSpeedNeed (11-15-2017)
Old 11-14-2017, 03:46 PM   #11
thebishman
CF Senior Member
My rule of thumb with CCMs are replace the pads when they only have 1/3rd of the pad thickness left, as I consider that a ‘buffer’ to stop rotor damage/increased oxidation. Yours are close but you may get another track weekend out of them. However it depends on what kind of track you’re going to and how hard you use the brakes.
thebishman is offline   Reply With Quote
Old 11-14-2017, 05:22 PM   #12
Bill Dearborn
Bill Dearborn's Avatar
They are good until the wear sensor turns on. Then you don't want to use them on track anymore. The wear sensor turns on when there is a fair amount of pad left (which gives the owner plenty of time to get the brakes replaced).
Bill
Bill Dearborn is online now   Reply With Quote
The Following 4 Users Say Thank You to Bill Dearborn For This Useful Post:
Fastmikefree (11-15-2017), ncstingray (11-15-2017), thebishman (11-15-2017), TopSpeedNeed (11-15-2017)
Old 11-15-2017, 01:42 PM   #13
thebishman
CF Senior Member
Quote:
Bill
My front wear sensors were 'vaporized' by the heat of the CCMs and wouldn't have warned me even when down to the backing plates Bill. I'd always recommend visually checking the pads by taking them out if necessary, especially the inner pads. That's a damn site cheaper than buying new CCM rotors.
Bish
Old 11-15-2017, 03:05 PM   #14
Bill Dearborn
Quote:
Bish
Don't disagree with visually checking the thickness of both pads as they can taper as they wear and be thinner in one spot than another. However, when the pad warning appeared on the DIC the sensor on my pads was melted/worn to the point the wire in the sensor had broken leaving just enough pad material for a couple hundred miles of street driving. I suspect most of the time that provides sufficient warning to pull into the pits and change pads.
Bill
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Do I need new pads ????
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    brake pad spring clips....which way? buckmeister2 C6 Corvette General Discussion 3 02-12-2017 04:27 PM
    brakes and rotors BK N 66 C1 & C2 Corvettes 7 08-11-2016 12:43 PM
    Best place to buy Raybestos pads Soloontario Autocrossing & Roadracing 6 07-26-2016 08:41 PM
    Changing pads on carbon ceramics Toilets C7 Z06 Discussion 8 07-12-2016 05:13 PM
    WTB factory z51 Brake pads mittens C6 Parts for Sale/Wanted 3 06-20-2016 12:30 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
