View Poll Results: Has your C7Z gone into Limp Mode from overtemp conditions
Yes
29
13.62%
No
184
86.38%
Voters: 213. You may not vote on this poll
Has your C7 Z06 overheated
#41
Received 1,390 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
My '12 ZR1 get above 230F+ in heavy traffic in Phoenix in the summer for instance. That is normal. However, my car does not have that fuel temp sensor to go into limp mode either.
#43
Please select, Yes or No, to indicate whether your 2015+ Z06 has overheated and gone into Limp Mode.
Please note, I am not talking about perception or if temps increased higher than 210. I am wondering if your car has stopped working completely and you were not able to drive it because it got too hot.
Thank you!
Thank you!
#44
Is it "normal," yes....Does it make you feel warm and fuzzy? Well warm yes, fuzzy, doubt it....
Have a look at this pic, the car isn't even really trying to cool off until over 225 and at low load, low speed, and some of the highest ambient temps in the country I am not surprised your car was running 233, heater or not. There was no airflow over the cooling system, something you get a lot of at speed, the ECM is programmed to run hot at low load, and the stock fans don't spin up until 225.
A 160 thermostat in your climate would make a big difference, coupled with programming the fans to come on accordingly (I know I know you shouldn't have to do anything it should be perfect from Chevrolet). Let's think about that, perfect from Chevrolet, lol.....
Most cars have dummy gauges, I bet that all the cars around you going slow in the heat are running just as hot but they have no way of knowing so they simply don't care.
Thanks EPA.
Thanks EPA.
Nice, Thanks. Still not "Fuzzy" though...
#45
Only tracked twice (sub 10 laps each ~ Laguna Seca, Thunderhill) multiple Autocross events and even bumper to bumper very heavy traffic in 90degree + temps. Never overheated to limp mode with my ‘15 A8/Z07.
#46
16 M7, stock cooling, ran hard in high 80s at most 90 degrees, oil never went above 270 coolant stayed at around 220 ish. This was done at thunder hill
#47
2017 Z07 M7 - so far so good.
#48
Even at the Bowling Green track
Thank you!
Thank you!
#49
2016 A8. Do not track the car. Never had a problem.
#51
voted no. Spirited driving. Buddy has his modified runs 9.7 @140 no cooking enhancements and ran back to back to back 9.7s within minutes at track rental have the slips to back it up. His and mine are A8s. Both pump gas. No race fuel for anyone wondering.
this poll is gin but is it a public poll where we can verify the minority as well as the majority? We all know fanboys and haters will always taint this type of poll. Just sayin.
#52
Received 2,379 Likes
#53
No on the over heating and I do not track mine.
#54
I had to say Yes because it did overtemp at the track once. I don't mean it shut down, I mean the warning came up on the HID and I had to drive differently - that's what I considered an overtemp event.
Keep in mind even with that, it's once in years of ownership that includes other (successful) track days too.
#55
Automatic and no overheating. Haven’t tracked it but drag raced it in 85 degree weather. Only pulled over once for about twenty minutes for me to take a break and the other 3 1/2 hours racing or standing in line with the engine running.
#56
Received 8,918 Likes
15 Z06 M7 I have it at the dealership now. I do spirited driving and really never look at the temps but it is in bursts...
Street temps haven't tracked yet but it will over heat for sure.
Has it over heated or went into Limp mode.. NO I haven't pushed but I know it will.
113* day in Vegas sat at 133* on freeway going 20-30 mph. Cranked heater to help keep it cool. If no heater it probably would of over heated.
88* in So Cal freeway driving 60 mph runs at 122* No spirited driving.
While driving it to the dealer Monday. 55* 40-50 mph runs at 195-197* Stop at stop light climbs to 203* would probably go higher if lights were longer.
sounds like its running at operating temperature.....thermostat doesn't even begin to open until 195 and is not fully open until 205 or so....
hopefully you voted no, based on your reality rather than your fears. this is a perfect example of the perception issue. you don't have a problem even remotely but you think you do or will. let us know when you experience limp mode.
There are plenty of out of date 50 year old perceptions of what temperatures are considered over heating. However, they are perceptions not facts.
Bill
#57
^^^I completely agree with Bill. Even my “old” ‘95 LT-1 will not turn the fans on high until the water temp reaches 230 degrees. Not sure where the temp sender is on the LT4 but on the early gen LT’s it was in the cylinder head. Old school perceptions from earlier generation engines, that had their temp senders in the intake manifolds, were anything over 200 degrees was overheating. The “key” words in the poll is “Limp mode”.
#58
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
2015, M7 N0....never i track to in the high 80's low 90's with NO aux GM radiator either. I have seen a few A8s overheat at the track and even an all stock 15, Z51!
Merry Christmas to all my CF friends
#60
OP. there is NO WAY there are 24 overheat votes that actually have this car and have had that happen. simply NO way.
Change the post to public lets take a look at who's voting here.
