Katech LPE GT35 38% Cam Fuel Lash Cap ?
Received 1,762 Likes
You can't make the lobe bigger as it wouldn't fit through the bearings/journals. You actually make the lobe -smaller- to overdrive the HPFP. 38% would be slightly smaller than a 32%. However, while all cams that have a smaller fuel lobe will likely function without a lash cap, that is NOT the correct way to install them as then you do not preload the pump properly.
The only way to overdrive a the HPFP with a cam lobe WITHOUT requiring a lash cap is by maintaining factory base of circle and increasing the size of the lobe, which we cannot do, or by increasing the number of excentrics on the lobe from 3 to 4 or 3 to 5. Basically going from a triangle lobe to a square lobe or pentagon shaped lobe.
Ant
Ant
Plus on the 38% should be even more off on the lobe to give that % of more gas.
This is one reason I am not going to do nothing to my short block at all until I have to do so. Maybe by then it will be totally clear so **** don't happen like after 5,k r 10,k mile due to not doing somethin correct. Ant believe me I trust your work & what you are saying on this stuff buddy... Robert
FYREANT (01-14-2018)
Sorry to revive a dead thread if this has been discussed already but can has anyone confirmed or denied if lash caps are required? Or if they are running any variation of a 38% over fuel lobe cam and are not having any issues? Thanks in advance!
Kind Regards,
Simon
Kind Regards,
Simon
I'm Batman..
Pro Mechanic
lash for the fuel lobe MUST be checked for each and every single install to know if a lash cap is needed or not. There is no generic answer based on the amount of overdrive on the lobe you have. It must be measured for each build. I have a guide on here that walks you through the process of checking it.
SteenC7Z (03-07-2021)
