Best tires?
Best tires?
Well looking for some ideas on what other members have replaced there tires and if they have a better ride and traction with a new set of tires. Looks like we are limited on brands.
Thanks for the advise
Mark
Mark
I just took a gamble on these. Figured I give them a try for a winter setup.
I like the fact that they only weigh 28 pounds compared to say the Nitto 345's which are 38 Pounds.
https://www.ebay.com/itm/1-X-New-Lex...JaIFqY&vxp=mtr
http://www.lexanitires.com/tire/lx-twenty
Also, every review I have found has been excellent.
I'm a broken record on this. Michelin Pilot Supersports, 295/30/19 F, 325/25/20 R. Don't let the 325 rear size fool you, it's actually wider than either of the 335 variants (SC2 or PS2). Grip is plenty good, much better in the cold than either of the stock options. Best way to buy is using the Discount Tire Direct sales/rebates when available and you'll net these down to ~$1,050 a set. I always keep a set in inventory. Luck if I get 10K out of the fronts.
NOT starting a tire war just letting you know I wouldn't run them if they were free. Been there, done that. FWIW, I fully realize if you just use your car for cruising around town or mild Sunday drives they are fine.
My question in the post above was in reference to an all season tire which a friend is wanting for winter and performance is not a concern. Not having any luck finding an all season tire which will fit the OEM 19/20 wheels. I know some are runningthe 305 Michelin on a 12" wheel but I just feel it's stretched too far. Pics I've seen look like the wheel extends well past the tire.
To answer the OP's question there is no better tire for the car than the OEM Michelin's if you want max performance. A trult remarkable tire. They are NOT junk like the old run flats...
cvp33 (12-30-2017)
IMHO, **** tires on the C7Z unless performance is not your main criteria. I bought a set and in less than a week returned them. Just terrible as they significantly compromised the excellent chassis.
Your a little hard on the SS non runflats but they are not the tire the MPSS is. The stock MPSS is spec'd by GM for the Corvette they are the best for a reason. .
For daily use, I install Conti ExtremeContacts -- better ride quality, great in rain, and not bad when snowfall isn't extreme. In the northeast, roads are in such horrible condition that my stock SS are just too harsh. However, use the SS for track days. Contis certainly not as crisp as the Michelins, but for around town and trips, it doesn't matter.
OK, so if you do decide to run the LEXAN in the front what size will you go with and where will you buy? I don't see a 19" that would be acceptable in their online catalog. But they also don't show the 345 in the catalog either...
Above is a link that shows all their tire sizes and also the specs. Also, the front tire thing is kinda of a dilemma, it does show however that they make a 275/30 in 19's. The 275 should work, difference is minimal with the width only having a .4" decrease and the diameter only being .2" smaller.
Based on the spec sheet do believe that the 345 and 275's are going to or already are discontinued, based on the sku/article number that is slightly different in session and since it doesn't show all the specs. I could be wrong and it may be that they are new sizes on a second release; just would have to call and see.
Here is a link showing differences in size between the 285 and 275.
https://www.tacomaworld.com/tirecalc...0r19-275-30r19
after reading all the replies I am more confused than ever. I guess I will go with what came on the car as original equipment which I hate with little to no traction below 50 degrees and the 4x4 feeling when turning hard going slow.
