Sponsored by: GEM Motorsports
2300 TVS Heartbeat!
Old 02-11-2019, 09:05 PM
  #241
MCK_Z06
Support Corvetteforum!
MCK_Z06's Avatar
^^^ Is that the LT1 SS lid?^^^
I did not know these were interchangeable but it looks better in my opinion.
The default 2300 lid for the C7's is as low or lower than the OEM 15-16 lids.
Old 02-12-2019, 08:19 AM
  #242
z51vett
z51vett's Avatar
Originally Posted by spinkick
That is to supply gas more than to keep valves clean.
They could have used larger injectors if that was the case. Look up other manufacturers that are now going to both. We have folks with 1000 hp without double injectors.
z51vett
Doug
Old 02-12-2019, 08:31 AM
  #243
CamOnlyJabroni
CamOnlyJabroni's Avatar
Originally Posted by 555ctsv
Yes sir, i just installed one in my 2016. I ended up swapping to a taller lid and even then the hood would close, but i took the liner off just in case and will try a 17+ liner eventually
which expansion tank is that? I like the black with billet cap.
Old 02-12-2019, 09:07 AM
  #244
555ctsv
555ctsv's Avatar
It is the LT1 magnuson lid, tuning is Thursday so we'll see how she does. If nothing else the lid looks cooler but i would expect having more volume there will help iat2's a bit (or whatever that temp is called in these engines). Had to trim the cowl just a bit in 2 spots but wasn't bad at all. Local shop offered to trade me lids, my flat lid plus my oem lt4 injectors which was fine with me
The tank is the LMR tank, it's massive. So big that i ended up having to install my catch can down in front of the front driver wheel well next to the horns. Im fine with that though, looks clean and should help keep the smell away from the A/C vent I loose the ability to see the "full" window on the can but I'll drain it frequently enough that won't matter. Came with an extension drain hose that i can pull down when needed
Old 02-12-2019, 01:44 PM
  #245
spinkick
spinkick's Avatar
z51vett
Doug
I bet they didnt want to change that part of the fuel system. Why create a new part number when you can share? Arent the injectors the same as the z06?
Old 03-10-2019, 04:21 PM
  #246
Z06Norway
Z06Norway's Avatar
Did u guys buy new belt or could you use the factory belt ?
tia
I noticed instruction said Gates K080865HD ??
Also, i noticed the way both in and out of supercharger is a 90 degree split.... how can anyone guarantee equal flow into both IC bricks with that design...
almost make me consider two pumps and/or a Y split out of pump and two return points to the tank ?
anyone ?
Old 03-10-2019, 07:40 PM
  #247
Mikec7z
Mikec7z's Avatar
Y at the pump is NOT a good idea, one side will flow faster than the other for sure.
Old 03-10-2019, 08:09 PM
  #248
Z06Norway
Z06Norway's Avatar
But a T connection right before SC is better ?
Would think a Y is better than a T, especially when flow comes straight in on one side and the other feeds from a 90 degree T ?
Mikec7z (03-10-2019)
Old 03-10-2019, 11:05 PM
  #249
Mikec7z
Mikec7z's Avatar
youre right, a T is not better, but adding any lengths of hose before the Y or the T is bad.
My guess is there is a sort of "terminal velocity" where speed or flow through the brick creates more and more resistance, so they actually balance out at any given moment. The fluid always takes the path of least resistance, which would be the brick that had less flow through it a nanosecond prior
Old 03-10-2019, 11:08 PM
  #250
Mikec7z
Mikec7z's Avatar
creating a crazy 8 for the 2 pumps like a zr1 has is easy... youd just need a zr1 HX that has the 2 paths, and I think you understand the rest.
Does that blower have it where a person can plum into each side separately, like the zr1 lt5 blower does?
Old 03-11-2019, 04:32 AM
  #251
Z06Norway
Z06Norway's Avatar
Default Its a TVS2300
https://d7xgwttsivb88.cloudfront.net.../magnuson3.png
Its a TVS2300, and yes, both sides have in/out...... But driver side has in/out with a T, and then hose crosses over to the other side...
So in my book, it has the worst connection + 10-12 inch longer travel hose to passenger IC... Both IC bricks have same internal resistance.
So again.... If i use a Y connection and make both hose in/out same length.... It should be better ... in my theory bubble :-)
The way Magnusson has plumbed this i am afraid passenger side will have a restricted flow ??
Or am i overthinking it ????
Mikec7z (03-11-2019)
Old 03-11-2019, 06:54 PM
  #252
Mikec7z
Mikec7z's Avatar
why was i thinking it also had a cooling brick in the top middle? I thought it had 3 bricks inside, no? If so, then how do the 2 inlets work? which side takes care of the 3rd brick?
JHEBERT, is this the same blower you have or did they do a refresh along the way?
Old 03-11-2019, 07:11 PM
  #253
Mikec7z
Mikec7z's Avatar
Rune, a crazy 8 system has a much better cooling ability all around, which is why they did so on the zr1, so lets plan for that, I can help you design how to do it if you need help. I can get you the pump part numbers that you will need, etc...
but im fishing for info how the 3rd brick works, if it has one, which i thought it did.
Figure out what those fittings are back there once you take off the stock cross over lines that go from drivers side to passenger side.
May as well start hunting for a zr1 blower HX for the front of the car.
The other thing is, you can hook it up "as is" but just know that you need to be on the look-out for a 2019 zr1 dual pass HX, or something similar, for a future upgrade
Old 03-12-2019, 12:10 PM
  #254
Z06Norway
Z06Norway's Avatar
Dont overthink it.....:-)
I have aBosch unit pump that has better flow than ZR1 pump
i have more IC heat exchangers
I was just worried of the solution Magnuson has chosen ....
It is IN / OUT on both siden through a 5/8 pipe.....
Problem was the right side is straight into and out of intercooler, and left side is a 90 degree T and then extra hose 12 inches...
a Y connection has less restriction and equal restriction to both sides.... and if hose is same length it seems to me to be way better that the delivered solution....
Not a fluid specialist but common sense..����
Old 03-12-2019, 12:56 PM
  #255
Mikec7z
Mikec7z's Avatar
in the crazy 8 system, you must have equal cooling to each of the 2 loops. You must have a HX that is split evenly in half into 2 paths, otherwise one bank will always be receiving less cooling than the other. And the bosch pump, you will need 2 of them. and they will also self destruct, because they dont have the cavitation shut down to clear the bubbles from the blade impellers like the zr1 pumps do.
Old 03-16-2019, 06:05 PM
  #256
andreas g.
andreas g.'s Avatar
[QUOTE=CamOnlyJabroni;1598863755]which expansion tank is that? I like the black with billet cap.[/QUOTE
what did the lid cost?
Old 03-16-2019, 06:07 PM
  #257
andreas g.
andreas g.'s Avatar
Old 03-19-2019, 07:30 PM
  #258
spinkick
spinkick's Avatar
Why not ask them? They are very responsive and then we would all have the official answer
Quick Reply: 2300 TVS Heartbeat!
