Roll racing A8
#101
St. Jude Donor '03-'04-'05-'06-'07-'08
Having had a C6 ZR1 and now a C7 Z06, I wonder if some of the replies in here meant to compare those and not the C6 and C7 Z06. The two Z06s are on different planets.
Roll racing with the C7 Z06, aero between stage 1 and 3 has a bigger impact than the transmission. Stage 3 loses several MPH.
With that said, I do wish they went with a dual clutch or at least the ability to customize the shift lights and/or points gear for gear with the A8.
#102
Don't try to manually shift for acceleration unless using the manual mode to JUST select a starting gear then put the selector back to drive once you go wot. The car is slower in manual. You cannot beat the computer on upshift selection.
I've done it. I can drive. The fastest way to run from a roll in the A8 is what I listed above.
and no gizmo... the C6Z is not a close contender to the C7Z stock for stock unless you get into the ridiculous above 150 area where the downforce ot the C7Z Hurts it. Not even close.
and cai vs cai cara the C7Z walks the c6Z beyond that. Take my word on it. The stock intake holds this car back like you couldn't believe. More so than any car I've ever driven owned or seen.
https://m.youtube.com/watch?v=GUDPpl...ature=youtu.be
