Z07 - is it or isn't it ?
looking at a '15 Z06
printed a build sheet at the local Chevy dealer
Model stated as a 1YZ07-2015 Corvette
However there isn't a separate line stating the Z07 option is on the car
Also, its, supposed , to have the FE6 suspension
Is that the " Mag Shocks " ?
I'd rather not make a 200mi drive and be disappointed
Get whole vin number go to parts counter give them vin they should be able to look up options. Actually last 8 of vin is all you need
z51vett
Doug
z51vett
Doug
The sticker with all the RPO (Regular Production Option) codes for the car is in the hatch or trunk. On that sticker you can see every option that was built into the car at the factory.
Check out this post:
https://www.corvetteforum.com/forums...post1596446895
In there you can see Bill's RPO sticker. He has a Z07, and you can see it down at the bottom left of the sticker:
And here's mine - you can see I'm lifting the carpet at the rear of the hatch. Both Bill and I have coupes:
Received 1,765 Likes
A 1YZ07 is just the model name for the "Corvette Z06 Coupe" , it has nothing to do with the Z07 option, if you were looking at a Z06 convertible it would be a 1YZ67, a ZR1 coupe is a 1YV07, ZR1 convertible is a 1YV67.
