Flex fuel conversion requirements
Received 2,379 Likes
No, you can't. The C7 ECM keeps a record of every time a change or flash is made.
Higgs, when you put some gasoline in, and then some E-85 (or the reverse order), how long does it take the two to mix evenly? Presumably, whatever goes in first will go into the driver side tank (where the engine supply fuel pump is) until that side is full, and then the rest goes into the passenger side tank. The "jet pump" in the passenger side tank, which is always pushing fuel to the driver side tank will eventually mix the two pretty evenly, but how long does this take, and might the proportions be pretty far off right after a fillup?
I don't know how long it takes for the two sides of the tank to equalize though. Here is a link:
https://www.corvetteforum.com/forums...gas-tanks.html
Received 1,817 Likes
This system has the left tank staying completely full and overflowing until the right tank runs out of fuel.
When your fuel gauge is at the halfway mark, your left tank is full and the right tank is empty.
When your fuel gauge is at the quarter mark, your left tank is half-full and your right tank is empty.
Harbgrogan (01-10-2020)
I have an E% gauge that reads from the flex fuel sensor. The mixture % starts to change pretty quickly when you add the opposite fuel that is currently in the tank and according to my gauge stabilizes after 7 to 15 minutes of driving. The flex fuel sensor reads E% of incoming fuel to the High-pressure pump so the ECM ethanol content adjustment is seamless if tuned correctly.
What I was partly wondering was whether prior to the fuel mixing completely, the E85 proportion might be so high that high-throttle operation would exceed the capacity of the fuel pumps.
the fuel pump's capacity does not depend on the flex fuel sensor reading.
I think rflow answered my question, that the gasoline and the E-85 seem to be sufficiently mixed in about 7-15 minutes of driving.
Right, but the volume of fuel required is higher with straight E-85, and can exceed the capacity of the pumps, so I was imagining a scenario where prior to being mixed with the gasoline to get E-40, the fuel pump might be drawing nearly straight E-85, and not be able to supply adequate fuel.
as I mentioned, mine has usually stabilized at about a mile of driving (but there is some stoplight driving going on in there.
that makes sense, my track doesn't have anything but race gas, no pump or ethanol. I really don't even like to go anymore, they don't even prep it. they have "No Prep" races so they can get away with it and pretend like they are capitalizing on Street Outlaws. they took it from a great track to a terrible track, which I am sure is what happens to most of them, unfortunately.
Does the DSX pump feed an auxiliary injector or what is it doing
https://dsxtuning.com/collections/au...-2014-corvette
It supplements the Low Side Fuel Pump to sustain fuel delivery.
#33
Hi, did you get a chance to evaluate the 'base' solution with just the flexfuel kit + CAI without a tune vs the same + tune? I am very interested to get your feedback? Thanks
#34
Well I still haven't installed the flexfuel kit (it's been a long fiasco) but I did do the baseline dyno on a mustang dyno and the numbers were retarded. I got a higher number on my stingray (which I'm pretty sure is wrong as well), so I've disregarded that shop. The flexfuel kit isn't going to change performance by itself, just allows you to run e85. Need the tune to make it work. The shop that's going to do the tune for me will do a baseline dyno, so once I can finally get that done, I'll post the #s. I just got it out of the shop after it spent 6 months in there, and i was going to get the tune about a week ago, but had to cancel my appt. Hopefully will be able to get it done within the next month.
Fastmikefree (05-07-2019)
#35
Thank you very much for the prompt reply! Appreciated.
#36
keep us updated.
I wanna run E85 on my Z with a stock engine. From what I've found, I just need the kit and a tune. The tune enables the flex fuel capability via the flex fuel sensor...
am I missing something?
#37
Originally Posted by Toddiesel;1596646031 I've been doing research and I'm coming across some info saying you need bigger injectors and a beefier fuel pump due to the fact that you have to use a lot more ethanol than gas to get the same efficiency.[/b
You will need to boost the capacity of the low side fuel system if you want to run much E-85. Running full E-85 is going to require major changes to the fuel system. This is the reason for using a meth injection system, as advised by Billy, to supplement the fuel system. Meth is a high octane ethanol fuel which will extend the capacity of the stock injectors because it is injected into the intake system separately. The DSX flex fuel sensor system will automatically compensate for the % E-85 you are running. I would not recommend running E-85 unless you are willing to upgrade the low side fuel system.
In my case on my 2016 A8 running a single nozzle meth injection with a low side fuel pump upgrade & stock injectors I am able to safely run 50% E-85 with 93 pump. The HP improvement for using the 50% E-85 is 40 RWHP.
Having said that, I've also seen info where things like the DSX bolt on flexfuel conversion kit will allow the ECM to adjust as needed and makes it sound like no additional upgrades (aside from a tune) is required. If not, how much extra power do you get with just a tune? I'm planning on adding a CAI and probably a lower pulley as well, but I'm more focused on what the flexfuel conversion can do and what it requires right now. Any info would be appreciated!
A tune, low side pump upgrade at a minimum if you want to too get a decent HP & TQ return . With just a tune and the DSX I am not sure how much E-85 you can run and what to expect in gains safely because for sure you are going to run out of low side capacity before you run a significant % of E-85. One other thing you are going to need is a gauge readout for the ethanol % you are running so you do not exceed the safe % established when the car is tuned. One of the competent tuners on the forum like Billy can probably answer what to expect with just a DSX and a tune.
#38
A tune, low side pump upgrade at a minimum if you want to too get a decent HP & TQ return . With just a tune and the DSX I am not sure how much E-85 you can run and what to expect in gains safely. One other thing you are going to need is a gauge readout for the ethanol % you are running so you do not exceed the safe % established when the car is tuned. One of the competent tuners on the forum like Billy can probably answer what to expect with just a DSX and a tune.
E85 requires 2 tunes. 93 Octane tune first, followed by removing fuel and adding E85 (multiple changes required to get ethanol content to 75 - 80% blend concentration), followed by E85 tune. After that, they then have to set up the flex fuel blend parameters so that the you can run any concentration of ethanol content from e10 - e80 and verify safe fueling and ignition parameters.
#39
The way the tune has been broken down for me is as follows:
#40
Sorry to bring this back from the dead - but has there been any progress made?
I am kicking around either running meth with full bolt ons or going the flex fuel route. Not sure what is easier. Seems like a lot of gray area here.
