Low dyno numbers?
I don't think the mph in the 1/4 mile tell the story for these cars. I see many doing 140+ mph in the 1/4. which would give them 800 hp or so. See there mods and it not = that many hp.
A dyno is a tool. No one ever won a race on one. Select a dyno, a good operator, and make several runs to establish a baseline. Then modify as you see fit. You will probably need a tune. Using the same dyno and operator rerun and evaluate. When I ran a DynoJet. I usually did a final power check after a tune and a good cool down for bragging rights, running 4 or 5 times back to back to ensure there were no "ringers" either high or low. If you have the money and time, run after each mod and see how each one performs.
Unfortunately I neither have a local strip nor a buddy with a Z06. Hell I don't even have a buddy with a stingray. Closest thing is a coworker with a focus RS and a former coworker (whom I never see) with a GTR. I think what I probably need to do is just bite the bullet and go to the dynojet here in town just to get peace of mind. I'll post my results once I get them. I appreciate everyone's input. Lot of good ideas! Would definitely help if I had a local drag strip!
Dropped it off at the dealership this morning. They said they'd check the fuel pressure, so we'll see what they say. I'll probably bite the bullet and take it to the track too. The nearest quarter mile track is 2 hours away, but meh. Do tracks still have the helmet requirement if you're under 12 seconds and roll cage if you're under 10 seconds? I haven't been to a drag strip since like 2000 when I was 18 and had a 240sx that was running 15s and I thought I was fast. I looked on their website and it didn't say anything about safety requirements.
The car does have a built in 0-60 and 1/4 mile timer and if you have a PDR it can also do it there. All you need is a nice empty road in Mexico.
Now if you totally hazed the tires and failed to hook it up at all it'd throw it off, but not much.
Here's a calculator. You need the accurate scale weight with you and fuel at the track though, so if the track doesn't have a scale, not that helpful.
http://www.wallaceracing.com/hpcalculatoreigth.php
Former Vendor
Just compare with similarly modified cars. For example mine does around 132mph (on average) at around 620whp on a dynojet.
I just swapped out my C7 stingray for a C7 Z06 last weekend. Took it to the dyno today to get some numbers. Now this is a mustang dyno, so they numbers do run a little lower than a dynojet, but it showed up as 471. Anyone else seen numbers this low? (btw I also took my stock stingray to this shop and it put down 450, which seems way high) https://www.youtube.com/watch?v=79gX...ature=youtu.be
I haven't noticed a 1/4 mile timer. I've seen the 0-60 timer (the start and stop times are fully adjustable. could be 40-150 if you wanted). Where's the 1/4 mile timer? And seriously??? A fire suit??? I doubt I'll ever break into the 9s as I won't ever be running slicks, but still!
Well the dealership did check the fuel pressure and said it was fine. The service advisor said they also did a diagnostic and couldn't find anything out of the ordinary. Given that and how I feel it performs compared to my stingray, I think the problem is with the guys running the mustang dyno. I'm still going to take it to the track within the next couple of weekends both for peace of mind and to get a baseline before I start putting mods on it (I've already ordered a halltech CAI and a flex fuel conversion). Here's something that concerns me though, out of the ihra safety rules http://www.ihra.com/images/2017/IHRA_2017_Rulebook.pdf
10.00 to 11.49 1/4 mile
6.50 to 7.49 1/8 mile
In addition to the following rules, also see IHRA Summit Sportsman Safety and General
Rules.
DRIVELINE: 1 Drive shaft loop mandatory on all entries.
FIRE EXTINGUISHERS: Properly secured fire extinguisher is required on all closed body
cars.
FLYWHEEL/CLUTCH: SFI 6.1. Flywheel shield, mandatory and clutch, pressure plate
and flywheel meeting SFI 1.1
FLEX PLATE: SFI 29.1 mandatory if vehicle exceeds 135 mph.
HELMET: SN, SA, M or K-2005 or newer mandatory.
MASTER CUTOFF: See General Regulations.
PROTECTIVE CLOTHING: Minimum, SFI 3.2A-5 jacket on open bodied entries.
Minimum 3.2A-1 jacket on closed body entries. Arm restraints are required on all open
bodied cars. Minimum SFI 3.3-1 gloves on open bodied entries.
ROLL CAGE/ROLL BAR: Roll cage is mandatory if entry has an altered floor or firewall,
or if vehicle exceeds 135 mph. Roll bar mandatory in all cars (including T-tops) running
10.00 to 11.49 ¼ mile or 6.50 to 7.35 1/8 mile, in convertibles running 11.00 to 13.49
¼ mile or 7.00 to 8.25 1/8 mile and in all dune-buggy-type vehicles running 12.00
seconds and slower ¼ mile or 7.50 1/8 mile.
So I need a driveshaft loop, a helmet, a fire extinguisher, a jacket, a "master cutoff" switch (which under the general rules elaborates that it has to have the word "off" clearly visible, which my "start" button does not) and an effin ROLL CAGE??? Is that all correct, or is there some exemption for stock cars in fine print somewhere??
Rules.
cars.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
#33
Rules.
cars.
Rules.
cars.
#34
Ehhhhhh. Maybe if it was just right down the street, but at a close to 5 hour round trip, I wouldn't want to get kicked out after just 1 pass. Guess I can call and see how strict they are
#35
You can go down to 10.00/135mph if 'stock' with approved helmet.
My understanding is that some of the newer OEM cars i.e. Hellcat, C7/Z06, etc. (according to the new rules) are allowed to run down to 10.00 and up to 135 MPH in the 1/4 if "Stock". I should know because I have been to different MD tracks (Capitol, Cecil, MIR) a number of times with my 10 second C7/Z06 coupe.
I fill out the form and where you enter your 'expected' ET I write 11/10 in that spot, if asked by the tech inspector (by the way some are lenient with the car inspection. Example: Drag Radials may be considered oem/street tires & not pay attention to whatever CAI you may have installed, some inspectors don't ever ask you to open the hood on these 'new' cars) However l say I really don't know what it's going to run which is a true statement i.e. anywhere from 11's down to 10.00
However you will need that approved helmet, long pants, shoes and "maybe" (not sure because I always have one) an approved fire jacket but from my readings here most likely not.
#36
My understanding is that some of the newer OEM cars i.e. Hellcat, C7/Z06, etc. (according to the new rules) are allowed to run down to 10.00 and up to 135 MPH in the 1/4 if "Stock". I should know because I have been to different MD tracks (Capitol, Cecil, MIR) a number of times with my 10 second C7/Z06.
I fill out the form and where you enter your 'expected' ET I write 11/10 in that spot, it asked by the tech inspector (by the way some are lenient with the car inspection. Example: Drag Radials may be considered oem/street tires & not pay attention to whatever CAI you may have installed, some inspectors don't ever ask you to open the hood on these 'new' cars) l say I really don't know what it's going to run which is a true statement i.e. anywhere from 11's down to 10.00
#37
You don't happen to know where this rule is? I'm not seeing it in the official rules, but it's stupid long so I could be missing it. I've called the track 3 times today and just keep getting voicemail. I'm guessing they don't have "office hours" as it were. Probably no one is there unless it's a track day, I'm guessing
Maybe try search, Goggle, etc.
#39
Received 1,816 Likes
Equipment required will pretty much depend on the track, the event, and whether the track and event are sanctioned by a group like the IHRA.
Sometimes I've been able to race with little more than an ancient worn-out helmet, and other times I've been required to wear a fire suit.
#40
